I’m trying to convert a windows FreeRTOS sempahore example to be used with efm32gg. This is example 16 in Amazon’s FreeRTOS Developer Guide located here
I believe I narrowed down the conversion to the difference between two commands:
There is no equivalent - the Windows port is a bit unique here in that
you can’t install a real handler. In the other ports (real MCUs), just
install the interrupt handler in the vector table as you would any other.
The Cortex-M has a set of SetPending registers, where if you set a bit
for a particular interrupt, that interrupt will execute if it is
enabled. There are probably CMSIS functions for the same, but I’m not sure.
Here is an example mainTRIGGER_INTERRUPT() macro from the LPC17xx
version of the book examples, which does actually appear to be using a
CMSIS function to pend the interrupt, despite what I just wrote above:
This is how the interrupt was configured in the first place:
static void prvSetupSoftwareInterrupt( void )
/* The interrupt service routine uses an (interrupt safe) FreeRTOS
API function so the interrupt priority must be at or below the priority
defined by configSYSCALL_INTERRUPT_PRIORITY. */
NVIC_SetPriority( mainSW_INTERRUPT_ID,
mainSOFTWARE_INTERRUPT_PRIORITY );
/* Enable the interrupt. */
NVIC_EnableIRQ( mainSW_INTERRUPT_ID );
and here is the handler:
void vSoftwareInterruptHandler( void )
portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
/* 'Give' the semaphore to unblock the task. */
xSemaphoreGiveFromISR( xBinarySemaphore, &xHigherPriorityTaskWoken );
/* Clear the software interrupt bit using the interrupt controllers
Clear Pending register. */
mainCLEAR_INTERRUPT();
/* Giving the semaphore may have unblocked a task - if it did and the
unblocked task has a priority equal to or above the currently executing
task then xHigherPriorityTaskWoken will have been set to pdTRUE and
portEND_SWITCHING_ISR() will force a context switch to the newly
unblocked
higher priority task.
NOTE: The syntax for forcing a context switch within an ISR varies
between
FreeRTOS ports. The portEND_SWITCHING_ISR() macro is provided as
part of
the Cortex M3 port layer for this purpose. taskYIELD() must never
be called
from an ISR! */
portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );
