peltier wrote on Tuesday, February 12, 2019:
Hello ,
I have some questions about the DataAbort Handler in the “CORTEX_A9_Zynq_ZC702” demo.
// from " FreeRTOS_asm_vectors.S ":
https://github.com/jameswalmsley/FreeRTOS/blob/master/FreeRTOS/Demo/CORTEX_A9_Zynq_ZC702/RTOSDemo/src/FreeRTOS_asm_vectors.S
FreeRTOS_DataAbortHandler: /* Data Abort handler /
stmdb sp!,{r0-r3,r12,lr} / state save from compiled code /
blx DataAbortInterrupt / DataAbortInterrupt :call C function here /
ldmia sp!,{r0-r3,r12,lr} / state restore from compiled code /
subs pc, lr, #4 / adjust return */
// from" Xilinx asm_vectors.s" https://github.com/Xilinx/embeddedsw/blob/master/lib/bsp/standalone/src/arm/cortexa9/gcc/asm_vectors.S
ldr r0, =DataAbortAddr
sub r1, lr, #8
str r1, [r0] / Stores instruction causing data abort /
bl DataAbortInterrupt / DataAbortInterrupt :call C function here /
subs pc, lr, #8 / points to the instruction that caused the Data Abort exception */
My questions are :
1/ Why have you used “blx” instruction rather than “bl” ?: “blx DataAbortInterrupt” ( blx changes the instruction set).
2/ Why have you modified the original handler that gives the possibility to know the instruction causing data abort: ( r0 is a parameter for Xilinx C function : DataAbortInterrupt )
https://github.com/Xilinx/embeddedsw/blob/master/lib/bsp/standalone/src/arm/common/xil_exception.c )
P.S: the same problem exists with PrefetchAbortHandler.
Thanks by advance.
Gilles Peltier
