fosfolipid wrote on Thursday, July 25, 2013:
hi,
this is default implementation for tickless idle mode in demo:
/* Enter a critical section but don't use the taskENTER_CRITICAL()
method as that will mask interrupts that should exit sleep mode. */
__disable_interrupt();
/* If a context switch is pending or a task is waiting for the scheduler
to be unsuspended then abandon the low power entry. */
if( eTaskConfirmSleepModeStatus() == eAbortSleep )
/* Restart SysTick. */
portNVIC_SYSTICK_CTRL_REG = portNVIC_SYSTICK_CLK_BIT | portNVIC_SYSTICK_INT_BIT | portNVIC_SYSTICK_ENABLE_BIT;
/* Re-enable interrupts - see comments above __disable_interrupt()
call above. */
__enable_interrupt();
/* Set the new reload value. */
portNVIC_SYSTICK_LOAD_REG = ulReloadValue;
/* Clear the SysTick count flag and set the count value back to
zero. */
portNVIC_SYSTICK_CURRENT_VALUE_REG = 0UL;
/* Sleep until something happens. configPRE_SLEEP_PROCESSING() can
set its parameter to 0 to indicate that its implementation contains
its own wait for interrupt or wait for event instruction, and so wfi
should not be executed again. However, the original expected idle
time variable must remain unmodified, so a copy is taken. */
xModifiableIdleTime = xExpectedIdleTime;
configPRE_SLEEP_PROCESSING( xModifiableIdleTime );
if( xModifiableIdleTime > 0 )
__WFI();
__DSB();
__ISB();
configPOST_SLEEP_PROCESSING( xExpectedIdleTime );
/* Stop SysTick. Again, the time the SysTick is stopped for is
accounted for as best it can be, but using the tickless mode will
inevitably result in some tiny drift of the time maintained by the
kernel with respect to calendar time. */
portNVIC_SYSTICK_CTRL_REG = portNVIC_SYSTICK_CLK_BIT | portNVIC_SYSTICK_INT_BIT;
call above. */
I’m a little bit confused when I try to understand it. Before the first ‘if’ statement there is ‘__disable_interrupt()’. During I was debugging program, I noticed that this function set PRIMASK to 1, so it prevents the activation of all exceptions with configurable priority. Let’s assume that condition eTaskConfirmSleepModeStatus() == eAbortSleep isn’t met - so MCU is forced to sleep because of __WFI(). And my question is - why does MCU wake up? SysTick interrupt has configurable priority so I think it should by masked by setting PRIMASK to 1, am I wrong? I’m reading documentation from ST, from ARM and from FreeRTOS but I can’t come to terms
