virgulap wrote on Wednesday, June 28, 2017:
could someone please clarify a point that I found in the change history of FreeRTOS revision?This point is regarding the context switching of task and is expressed in the history doc as: + Previously, when a task left the Blocked state, a context switch was
performed if the priority of the unblocked task was greater than or equal
to the priority of the Running task. Now a context switch is only
performed if the priority of the unblocked task is greater than the
My understanding is here that in case of task that have the same priority the Round Robin wont be possible anymore? Or am I wrong? So the specific question is, if updating to version V8.0.0 the current priorities of the task should be reorganized.
Thank you in advance!
