I am dealing with the tests provided in the repository FreeRTOS-Community-Supported-Demos so that when they pass I can then make a pull request to this repo.
The target board is the R9A02G021.
The problem I am facing with the RegTests is that the prvRegisterTestnTask do not get scheduled after a short time. I get “No errors” for two times (the first time it actually gets 5 seconds), but then it immediately prints the error message. It looks like only the prvCheckTask thread gets scheduled after the second print of “No errors”. I thought that the problem was vTaskDelayUntil( &xNextWakeTime, xCycleFrequency ); but it actually gets the values
xNextWakeTime=0 and xCycleFrequency=5000,
then xNextWakeTime=5000 and xCycleFrequency=5000
(up to this point it prints two time “No errors”) but then with
xNextWakeTime=10000 and xCycleFrequency=5000
it starts printing the error message for regtests
But I am not 100% sure it is the problem. Can someone help me understand what is going on?
My code is:
* FreeRTOS V202212.00
* Copyright (C) 2020 Amazon.com, Inc. or its affiliates. All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy of
* this software and associated documentation files (the "Software"), to deal in
* the Software without restriction, including without limitation the rights to
* use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
* the Software, and to permit persons to whom the Software is furnished to do so,
* subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* https://www.FreeRTOS.org
* https://github.com/FreeRTOS
/* Scheduler include files. */
#include "FreeRTOS.h"
#include "task.h"
/* Interface include files. */
#include "RegTests.h"
/* Tasks that implement register tests. */
static void prvRegisterTest1Task( void *pvParameters );
static void prvRegisterTest2Task( void *pvParameters );
static void prvRegisterTest3Task( void *pvParameters );
static void prvRegisterTest4Task( void *pvParameters );
/* Flag that will be latched to pdTRUE should any unexpected behavior be
detected in any of the tasks. */
static volatile BaseType_t xErrorDetected = pdFALSE;
/* Counters that are incremented on each cycle of a test. This is used to
detect a stalled task - a test that is no longer running. */
static volatile uint32_t ulRegisterTest1Counter = 0;
static volatile uint32_t ulRegisterTest2Counter = 0;
static volatile uint32_t ulRegisterTest3Counter = 0;
static volatile uint32_t ulRegisterTest4Counter = 0;
( void ) pvParameters;
for( ; ; )
/* 1. Fill the registers stored as part of task context with known values.
* 2. Force a context switch.
* 3. Verify that all the registers contain expected values.
* 4. If all the register contain expected values, increment ulRegisterTest1Counter.
// note that a0 is used for the return value
// 1.
asm volatile (
"li a1, 431\n"
"li a2, 432\n"
"li a3, 433\n"
"li a4, 434\n"
"li a5, 435\n"
"li a6, 436\n"
"li a7, 437\n"
// 2.
vTaskDelay(0);
// 3.
asm volatile (
"li t0, 431\n"
"bne a1, t0, reg1_err\n"
"li t0, 432\n"
"bne a2, t0, reg1_err\n"
"li t0, 433\n"
"bne a3, t0, reg1_err\n"
"li t0, 434\n"
"bne a4, t0, reg1_err\n"
"li t0, 435\n"
"bne a5, t0, reg1_err\n"
"li t0, 436\n"
"bne a6, t0, reg1_err\n"
"li t0, 437\n"
"bne a7, t0, reg1_err\n"
"j reg1_passed\n"
asm volatile (
"reg1_err:\n"
"j reg1_err\n"
// 4.
asm volatile (
"reg1_passed:\n"
"la t0, ulRegisterTest1Counter # Load address of ulRegisterTest1Counter into t0\n"
"lw t1, 0(t0) # Load the value of ulRegisterTest1Counter into t1\n"
"addi t1, t1, 1 # Increment t1 by 1\n"
"sw t1, 0(t0) # Store the updated value back to ulRegisterTest1Counter\n"
for( ; ; )
* 4. If all the register contain expected values, increment ulRegisterTest2Counter.
// 1.
asm volatile (
"li a1, 681\n"
"li a2, 682\n"
"li a3, 683\n"
"li a4, 684\n"
"li a5, 685\n"
"li a6, 686\n"
"li a7, 687\n"
// 2.
vTaskDelay(0);
// 3.
asm volatile (
"li t0, 681\n"
"bne a1, t0, reg2_err\n"
"li t0, 682\n"
"bne a2, t0, reg2_err\n"
"li t0, 683\n"
"bne a3, t0, reg2_err\n"
"li t0, 684\n"
"bne a4, t0, reg2_err\n"
"li t0, 685\n"
"bne a5, t0, reg2_err\n"
"li t0, 686\n"
"bne a6, t0, reg2_err\n"
"li t0, 687\n"
"bne a7, t0, reg2_err\n"
"j reg2_passed\n"
asm volatile (
"reg2_err:\n"
"j reg2_err\n"
// 4.
asm volatile (
"reg2_passed:\n"
"la t0, ulRegisterTest2Counter # Load address of ulRegisterTest2Counter into t0\n"
"lw t1, 0(t0) # Load the value of ulRegisterTest2Counter into t1\n"
"sw t1, 0(t0) # Store the updated value back to ulRegisterTest2Counter\n"
for( ; ; )
* 4. If all the register contain expected values, increment ulRegisterTest3Counter.
// 1.
asm volatile (
"li a1, 991\n"
"li a2, 992\n"
"li a3, 993\n"
"li a4, 994\n"
"li a5, 995\n"
"li a6, 996\n"
"li a7, 997\n"
// 2.
vTaskDelay(0);
// 3.
asm volatile (
"li t0, 991\n"
"bne a1, t0, reg3_err\n"
"li t0, 992\n"
"bne a2, t0, reg3_err\n"
"li t0, 993\n"
"bne a3, t0, reg3_err\n"
"li t0, 994\n"
"bne a4, t0, reg3_err\n"
"li t0, 995\n"
"bne a5, t0, reg3_err\n"
"li t0, 996\n"
"bne a6, t0, reg3_err\n"
"li t0, 997\n"
"bne a7, t0, reg3_err\n"
"j reg3_passed\n"
"reg3_err:\n"
"j reg3_err\n"
// 4.
"reg3_passed:\n"
"la t0, ulRegisterTest3Counter # Load address of ulRegisterTest3Counter into t0\n"
"lw t1, 0(t0) # Load the value of ulRegisterTest3Counter into t1\n"
"sw t1, 0(t0) # Store the updated value back to ulRegisterTest3Counter\n"
for( ; ; )
// 1.
asm volatile (
"li a1, 111\n"
"li a2, 112\n"
"li a3, 113\n"
"li a4, 114\n"
"li a5, 115\n"
"li a6, 116\n"
"li a7, 117\n"
// 2.
vTaskDelay(0);
// 3.
asm volatile (
"li t0, 111\n"
"bne a1, t0, reg4_err\n"
"li t0, 112\n"
"bne a2, t0, reg4_err\n"
"li t0, 113\n"
"bne a3, t0, reg4_err\n"
"li t0, 114\n"
"bne a4, t0, reg4_err\n"
"li t0, 115\n"
"bne a5, t0, reg4_err\n"
"li t0, 116\n"
"bne a6, t0, reg4_err\n"
"li t0, 117\n"
"bne a7, t0, reg4_err\n"
"j reg4_passed\n"
"reg4_err:\n"
"j reg4_err\n"
// 4.
"reg4_passed:\n"
"la t0, ulRegisterTest4Counter # Load address of ulRegisterTest4Counter into t0\n"
"lw t1, 0(t0) # Load the value of ulRegisterTest4Counter into t1\n"
"sw t1, 0(t0) # Store the updated value back to ulRegisterTest4Counter\n"
void vStartRegisterTasks( UBaseType_t uxPriority )
BaseType_t ret;
ret = xTaskCreate( prvRegisterTest1Task, "RegTest1", configMINIMAL_STACK_SIZE, NULL, uxPriority, NULL );
configASSERT( ret == pdPASS );
ret = xTaskCreate( prvRegisterTest2Task, "RegTest2", configMINIMAL_STACK_SIZE, NULL, uxPriority, NULL );
// ret = xTaskCreate( prvRegisterTest3Task, "RegTest3", configMINIMAL_STACK_SIZE, NULL, uxPriority, NULL );
// configASSERT( ret == pdPASS );
// ret = xTaskCreate( prvRegisterTest4Task, "RegTest4", configMINIMAL_STACK_SIZE, NULL, uxPriority, NULL );
BaseType_t xAreRegisterTasksStillRunning( void )
static uint32_t ulLastRegisterTest1Counter = 0, ulLastRegisterTest2Counter = 0;
static uint32_t ulLastRegisterTest3Counter = 0, ulLastRegisterTest4Counter = 0;
/* If the register test task is still running then we expect the loop
* counters to have incremented since this function was last called. */
if( ulLastRegisterTest1Counter == ulRegisterTest1Counter )
xErrorDetected = pdTRUE;
if( ulLastRegisterTest2Counter == ulRegisterTest2Counter )
// if( ulLastRegisterTest3Counter == ulRegisterTest3Counter )
// xErrorDetected = pdTRUE;
// if( ulLastRegisterTest4Counter == ulRegisterTest4Counter )
ulLastRegisterTest1Counter = ulRegisterTest1Counter;
ulLastRegisterTest2Counter = ulRegisterTest2Counter;
ulLastRegisterTest3Counter = ulRegisterTest3Counter;
ulLastRegisterTest4Counter = ulRegisterTest4Counter;
/* Errors detected in the task itself will have latched xErrorDetected
* to true. */
return ( BaseType_t ) !xErrorDetected;
I know that using a registers is not the best/complete way of testing, but I doubt it the source of the problem.
EDIT: Commenting the lines inside xAreRegisterTasksStillRunning it magically works:
Can someone help me understand what is going on here?
