anonymous wrote on Tuesday, October 25, 2011:
Dear FreeRTOS support,
I’ve made a stripped down program with the RTOS for the processor PIC32MX320F128H with a blinking LED for a test.
However, it refuses to start at all. Is there any thing I need to put inside for a bare essential RTOS to work?
Here’s the code:
#pragma config POSCMOD=XT, FNOSC=PRIPLL
#pragma config FPLLIDIV=DIV_2, FPLLMUL=MUL_18, FPLLODIV=DIV_1
#pragma config FPBDIV=DIV_2, FWDTEN=OFF, CP=OFF, BWP=OFF
#include <p32xxxx.h>
#include <system.h>
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "croutine.h"
#include "timers.h"
void UART1_Init();
void UART1_putc(unsigned char);
void UART1_puts(unsigned char*);
static void prvSetupHardware( void );
static void prvCheckTask( void *pvParameters ) __attribute__((noreturn));
static void vLEDTask(void* pvParameters);
const portTickType smallDelay = 500 / portTICK_RATE_MS;
unsigned long i = 0;
int main()
prvSetupHardware();
xTaskCreate(vLEDTask, "LED", configMINIMAL_STACK_SIZE, NULL, tskIDLE_PRIORITY + 1, NULL );
vTaskStartScheduler();
return 0;
void UART1_Init()
U1BRG = 77;
U1MODE = 0x8008;
U1STAbits.UTXEN = 1;
U1STAbits.URXEN = 1;
void UART1_putc(unsigned char inputc)
while(U1STAbits.UTXBF);
U1TXREG = inputc;
void UART1_puts(unsigned char* string)
while(*string)
UART1_putc(*string++);
AD1PCFG = 0xFFFF; //All pins as Digital
DDPCONbits.JTAGEN = 0; //Disable the JTAG port
SYSTEMConfigPerformance(72000000);
mOSCSetPBDIV(OSC_PB_DIV_2);
INTEnableSystemMultiVectoredInt();
TRISE = 0x0000;
PORTE = 0x0000;
PMCONbits.ON = 0;
for(;;)
PORTEbits.RE0 ^= 1;
vTaskDelay(1000);
The LEDTask is to toggle the LED for each second, but it didn’t even start.
Thanks for the support.
