Hello Everyone,
I hope you all are doing well.
I’m facing a problem with Broadcast IP.
If i ping from FPGA board (MPF100 Microsemi polarfire module) to any other computer either the plateform is windows or linux with a predefined static IP then it works in both directions (FPGA board to computer and computer to FPGA board) and i will get the ping response.
If i change the static IP to broadcast IP(255.255.255.255) then the ping is successful from FPGA board to Linux Computer. But if i ping with broadcast IP (255.255.255.255) from Linux Computer then i only get reply from my linux computer but not from the FPGA board.
Can anyone have an idea what i’m missing with respect to Broadcast IP, From where i need to enable it for Polarfire FPGA Module. There should be some way because in Linux i have to run following command to Enable Broadcast IP
sysctl -w net.ipv4.icmp_echo_ignore_broadcasts=0
and then update the routing table.
I also would like to tell you that DHCP is working properly and assign IP address with DHCP server.
I could not understand why Broadcast is not working because in DHCP discovery the client send Broadcast message and server acknowledge it and then assign IP.
I tried with Both by enabling (dynamic IP) and Disabling (static IP) DHCP but board is not responding.
#define ipconfigUSE_DHCP 0 or 1
I would also like to tell you i also tried by setting filter packets to 1 in FreeRTOSIPConfigDefaults.h but it’s not working.
#define ipconfigETHERNET_DRIVER_FILTERS_PACKETS 1
If i connect both linux computer and ping with Broadcast IP, there i’m getting acknowledge from both computers.
On FPGA side i’m using Opencores tri-mode ethernet MAC.
If anyone has an idea either it’s a problem with FreeRTOS configuration or with Hardware then please share
Thank you very much.
