racemouse wrote on Friday, August 10, 2007:
Ok. This was the theory :
BootStrapper sets up the SWI interrupt vector to swi_handler in internal RAM. When the BootLoader in external ram interrupts it does not vector to the swi_handler in external RAM but to the swi_handler in internal RAM. I therefore needed to setup the correct interrupt vectors. I did it like this:
void main( void )
extern void swi_handler(void);
// Copy contents from Flash address 0x00 to 0x20 to RAM 0x00 to 0x20
memcpy ((int *)0x00200000, (int *)0x00100000, 128);
// Load the address of interrupt handlers into the correct places
dest_address = (int*)0x00200020;
*dest_address = (int*)0x20000034;
dest_address = (int*)0x00200024;
*dest_address = &swi_handler;
dest_address = (int*)0x00200028;
*dest_address = &Kernel_reboot;
dest_address = (int*)0x0020002C;
dest_address = (int*)0x00200030;
*dest_address = (int*)0x2000004C;
// Remap so the RAM starts at address 0x00000000
AT91C_BASE_MC->MC_RCR |= AT91C_MC_RCB;
vMainInit ();
vTaskStartScheduler ();
And now it works as it should
Thanks for the help to those who helped and I hope someone else can use this.
Cheers
RaceMouse
