I am using FreedomStudio v4.7.2.2020-06-3 and QEMU v5.1.0 on OSX Catalina v10.15.7.
I am following the tutorial for RTOS Demo for RISC-V QEMU sifive_e Model (https://www.freertos.org/RTOS-RISC-V-FreedomStudio-QMEU.html) except the demo project specified in this tutorial is not included in the download zip. I am attempting to use RISC-V-Qemu-sifive_e-Eclipse-GCC demo project instead in the hopes that it will work since FreedomStudio is based off of Eclipse. I can see where the build/debug configuration would be off and I did my best to fix it.
When debugging the demo project, nothing is printed to the QEMU console window.
mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1, so i am expecting ‘blink’ to be printed periodically to the QEMU console window.
I am quite inexperienced with the FreedomStudio IDE, QEMU, and FreeRTOS. I am trying to learn about rtos and risc-v. Any help or guidance is appreciated. I tried the blinky demo in the Freedom e SDK with no luck either. Some other error (which I am inquiring about in the sifive forums) is preventing me from moving forward with that version of the blinky demo.
Thank you!
