FreeRTOS API functions must not be called from within a critical section - Please explain
ingamow wrote on Monday, January 14, 2019:
From the documentation of taskENTER_CRITICAL(), I’ve seen this info “FreeRTOS API functions must not be called from within a critical section”. In one of my projects using Cortex M0, I happen to use xQueueSendFromISR() from within a critical section in an ISR. I face no problems in using this, so just wanted to know the EXACT TECHNICAL REASON of why this is mentioned.
*P.S : I could only find Answers like “As a general Rule of Thumb …” . Can anyone please explain it in detail ? *
richarddamon wrote on Monday, January 14, 2019:
First, you should not be calling taskENTER_CRITICAL inside an ISR, as it doesn’t end in FromISR (there is on many port a taskENTER_CRITICAL_FROM_ISR routine that can be used if the port supports nested interrupts), and I don’t think that function has the same note. (I don’t know off hand if the M0 allows nested interurpts so it provides/needs a critical section in ISRs).
The big issue is that if you call a FreeRTOS function that blocks inside a critical section, you run into an issue that the taskENTER_CRITICAL call says no other task or ISR will be run during it, but the blocking says that some other task should be run, so the result will by necessity break some expectation. ISRs never block, so this can’t be an issue for a critical section in an ISR.
Many ports implement the scheduler call via a interrupt call, so it can’t be called in a critical section.
rtel wrote on Monday, January 14, 2019:
The Cortex-M0 does not have a basepri register, so critical sections
don’t mask just a subset of interrupt priorities as per the
Cortex-M3/4/7 ports, but all interrupts - so interrupt nesting isn’t
supported directly by the kernel for that port. Therefore a critical
section inside an interrupt is not necessary, and the “From ISR”
versions of those functions referred to by Richard D are just null macros.
The ‘rule of thumb’ description is given because it is not only
dependent of the API function in use, but also dependent on the FreeRTOS
port in use. For example, consider a port that uses a trap to perform a
context switch synchronously - in a critical section the trap may just
cause an exception (because of the state of the processor when you are
in a critical section), whereas other architectures may not. In any
case, anything that is supposed to block of switch to a higher priority
task that doesn’t because you are in a critical section can cause
application logic errors.
ingamow wrote on Tuesday, January 15, 2019:
Thank you guys. I’m using a 4 year old code in which it said that taskENTER_CRITICAL was introduced in the ISR context to fix a bug that occured years back. It works perfectly now, but under some rare cases we are having some issues. As far as FreeRTOS part is concerned, this is the one in which we are violating the rule. So we are now trying to find an alternative for this approach and is planning to use taskENTER_CRITICAL_FROM_ISR (which is not a null macro). In fact, this is what is done inside that macro :-
** asm volatile(
" mrs r0, PRIMASK \n"
" cpsid i \n"
" bx lr "
Will this make any difference ?
rtel wrote on Tuesday, January 15, 2019:
occured years back.
Really? Which code is that? Can you please give more information.
It’s a confidential code developed and maintained by previous developers in our company.
But it looks something like this :
taskENTER_CRITICAL();
if(xQueueSendFromISR( …))
taskEXIT_CRITICAL();
this is in an ISR context, and the addition of critical section is what is mentioned to be done as a workaround for a bug fix that occured long back (Nobody remembers the exact reason). I dont want to bring around new bugs in removing this but just wanted to know answers to these questions
  1. Here, will the use of taskENTER_CRITICAL_FROM_ISR (which is not a null macro in our case as mentioned above) make any difference?
  2. Is there an alternative approach for the above mentioned code?
richard_damon wrote on Tuesday, January 15, 2019:
If the port supports nested interrupts, then taskENTER_CRITICAL_FROM_ISR, which should be called something like:
uint32_t mask = taskENTER_CRITICAL_FROM_ISR();
will block interrupts up to the level that is allowed to use the FreeRTOS FromISR API, from occuring until the next occurance of
taskEXIT_CRITICAL_FROM_ISR(mask);
(note the additon of a parameter in the calls)
If it doesn’t support nested interrupts, then there is no need to do this, as nothing will be able to interfere.
If nesting IS possible (or was in an earlier version of the code) the Critical Section may have been needed if some other ISR might play with that Queue also.
ingamow wrote on Thursday, January 17, 2019:
Thanks Richard. Now I know why taskENTER_CRITICAL_FROM_ISR will be useless in our case.
The thing which I still don’t understand is :
In any case, anything that is supposed to block of switch to a higher priority
Can you explain this point in detail. How does context switching in a critical region cause application Logic errors ?
richarddamon wrote on Thursday, January 17, 2019:
A context switch can’t happen in a critical setion, thats why you have a critical section, so you can’t switch to some new context.
The issue comes if you want to test the status of something, and react appropriately, and not have to worry that something else might have changed the conditon. Note that xQueueSendFromISR internally uses a critical section for accessing the queue so it can test that there is room, and using it, without problems that someone else takes the space that it thought was available.
In the code you posted, which had to be incomplete as the critical section was only ended if the send succedded, perhaps the else clause to handle a failed send needed to assume that some other ISR wasn’t going to come along and make room in the queue during its recovery. That would require a critical section.
It could also be that at one point there was more code after the Send and before the end critical, that has since been removed, and now the critical section isn’t needed in this version.
+Akshay AJ xxxx@xxxx.com
On Thu, Jan 17, 2019 at 5:10 PM Richard Damon <
critical section.
Please explain
https://sourceforge.net/p/freertos/discussion/382005/thread/7beb78c86f/?limit=25#3a80
Sent from sourceforge.net because you indicated interest in
SourceForge.net: Log In to SourceForge.net
To unsubscribe from further messages, please visit
Regards,
Akshay A J
https://www.linkedin.com/in/akshay-a-j-a7744b106
