pamdev wrote on Wednesday, June 21, 2017:
Hi! My team is trying to use TC1798 evaluation board with FreeRTOS 9.0.0.
I’m experiencing big trubles porting FreeRTOS Demo project for TC1782 to the latest(?) version of HighTec Development Platform (Version: 1.6.2.20170130-b29c1f1). As I have concluded the Demo project was made for the Platform version prior to 1.1.0 (though it seems to build on version 1.2 platform). I did my best trying to port the project code for the HighTec Development Platform but nothing helps. Build fails with message:
FreeRTOS_Demo: Each LDF project needs an LDF project nature (since version 1.1.0)
I moved the FreeRTOS Demo source code folder to a new empty HighTec project for TC1782 and copied some config setting from demo to the new project (e.g. include paths). I tried to build the project but got the error from ‘FreeRTOSConfig.h’ file that has the following line:
#error Ensure CreateProjectDirectoryStructure.bat has been executed before building. See comment immediately above.
The comment itself tells that you can remove that line and refresh the project. That’s what I did but …
The next build gave lots of errors like this:
"C:\HighTec\toolchains\tricore\v4.9.1.0-infineon-1.1/bin/tricore-gcc" -c -I"../h" -I"C:\HighTec\toolchains\tricore\v4.9.1.0-infineon-1.1\tricore\include" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo\Common_Demo_Source\include" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo\FreeRTOS_Source\include" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo\FreeRTOS_Source\portable\GCC\TriCore_1782" -fno-common -Os -g3 -W -Wall -Wextra -Wdiv-by-zero -Warray-bounds -Wcast-align -Wignored-qualifiers -Wformat -Wformat-security -DTRIBOARD_TC1782 -fshort-double -mcpu=tc1782 -mversion-info -MMD -MP -MF"RTOSDemo/FreeRTOS_Source/portable/MemMang/heap_2.d" -MT"RTOSDemo/FreeRTOS_Source/portable/MemMang/heap_2.d" -o "RTOSDemo/FreeRTOS_Source/portable/MemMang/heap_2.o" "../RTOSDemo/FreeRTOS_Source/portable/MemMang/heap_2.c"
'Finished building: ../RTOSDemo/FreeRTOS_Source/portable/MemMang/heap_2.c'
'Building file: ../RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.c'
'Invoking: TriCore C Compiler'
"C:\HighTec\toolchains\tricore\v4.9.1.0-infineon-1.1/bin/tricore-gcc" -c -I"../h" -I"C:\HighTec\toolchains\tricore\v4.9.1.0-infineon-1.1\tricore\include" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo\Common_Demo_Source\include" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo\FreeRTOS_Source\include" -I"C:\Users\TVT\workspace\CORRIDA\RTOSDemo\FreeRTOS_Source\portable\GCC\TriCore_1782" -fno-common -Os -g3 -W -Wall -Wextra -Wdiv-by-zero -Warray-bounds -Wcast-align -Wignored-qualifiers -Wformat -Wformat-security -DTRIBOARD_TC1782 -fshort-double -mcpu=tc1782 -mversion-info -MMD -MP -MF"RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.d" -MT"RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.d" -o "RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.o" "../RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.c"
../RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.c: In function 'pxPortInitialiseStack':
../RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.c:170:3: error: stray '$' in program
pulLowerCSA = portCSA_TO_ADDRESS( _mfcr( $FCX ) );
In file included from C:\Users\TVT\workspace\CORRIDA\RTOSDemo\FreeRTOS_Source\include/portable.h:94:0,
from C:\Users\TVT\workspace\CORRIDA\RTOSDemo\FreeRTOS_Source\include/FreeRTOS.h:104,
from ../RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.c:81:
../RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.c:170:37: error: incompatible type for argument 1 of '_mfcr'
C:\Users\TVT\workspace\CORRIDA\RTOSDemo\FreeRTOS_Source\portable\GCC\TriCore_1782/portmacro.h:142:62: note: in definition of macro 'portCSA_TO_ADDRESS'
#define portCSA_TO_ADDRESS( pCSA ) ( ( uint32_t * )( ( ( ( pCSA ) & 0x000F0000 ) << 12 ) | ( ( ( pCSA ) & 0x0000FFFF ) << 6 ) ) )
In file included from ../RTOSDemo/FreeRTOS_Source/portable/GCC/TriCore_1782/port.c:76:0:
c:\hightec\toolchains\tricore\v4.9.1.0-infineon-1.1\tricore\include\machine\intrinsics.h:111:10: note: expected 'unsigned int' but argument is of type 'FCX_t'
unsigned _mfcr (const unsigned __regaddr)
Is it possible to use FreeRTOS with the latest HighTec Development Platform? If the answer is yes is there possibility to port FreeRTOS TC1782 Demo to this invironment?
Thanks in advance!
With best wishes, Theodore
