FreeRTOS and GPIO interrupt handler
k1mgy wrote on Thursday, November 02, 2017:
AT91SAMG
Atmel Studio
ASF
FreeRTOS 8.0.9
To service a touch screen, I’ve established a GPIO line configured to fire an interrupt service routine when the screen is touched. This will then cause certain actions to occur based on the touch event.
Communications with the touch screen is accomplished through the SPI bus. I don’t want to re-write my HAL to use the FreeRTOS SPI driver.
Is it legal to handle interrupts outside of FreeRTOS? By outside, I mean that the ISR is not managed by the FreeRTOS scheduler.
Are there any reason to do this differently, and if so, can you suggest something?
ps: the ISR fires and seems to work fine with a simple FreeRTOS task list. The ISR does not eat up much time, however.
rtel wrote on Friday, November 03, 2017:
FreeRTOS doesn’t manage the interrupts, but there are rules on how you
use the API from inside an interrupt service routine. Roughly the rules
are:
  • don’t call an API function that does not end in 'FromISR" from inside
    an ISR.
  • don’t call any API function from an interrupt that has a priority
    above configMAX_SYSCALL_INTERRUPT_PRIORITY.
I would recommend reading the book that is provided as a free PDF
download: http://www.freertos.org/Documentation/RTOS_book.html and the
following page: http://www.freertos.org/RTOS-Cortex-M3-M4.html
k1mgy wrote on Monday, November 06, 2017:
Thank you. I read the material on interrupts. I’m including the relevant code below.
My processor is the AT91SAMG55 (ARM Cortex-M4). The data sheet tells me that priority 0 is the highest (opposite of most other devices). What I can’t fathom is the maximum number of interrupt priorities available. It’s either a 4 or 8 bit register… but there are some complexities. Maybe this doesn’t matter. Uncertain how this plays into the FreeRTOS event priority scheme or even if these are related. For now I am going to assume that the priority scheme relies on the CPU and therefore that 0 has the highest priority.
Questions:
1.** configMAX_PRIORITIES** is set to 5 in FreeRTOSConfig.h. Is this the setting to establish the max number of priorities available on the device? It’s unclear from the description of this setting. For now, since priority 0 = max on the CPU, I have set #tskIDLE_PRIORITY to 5 (assuming for the moment that 5 is the lowest).
  1. Are interrupts turned off at any time during running of the scheduler? It appears at first glance this is so, as my GPIO interrupt handler is not triggered during scheduler execution.
  2. For now, I have set up a simple boolean token that will, I hope, prevent any conflict between two timer tasks from accessing the SPI buss at the same time. A task that needs access to the SPI must get the token. If it does not, then any SPI calls within the task are disallowed. I’m concerned however that two timer-based tasks might request the token simultaneously. Hopefully these will not clash. I’d rather use a FreeRTOS-based token that guarantees its integrity. Any suggestions?
Priority constants:
#define tskIDLE_PRIORITY			( ( UBaseType_t ) 5U )
#define TOUCHPARSE_TASK_PRIORITY		    ( 1 )
#define TOUCHPARSE_STACK_SIZE				(1024/sizeof(portSTACK_TYPE))
#define ADC_CONVERT_TASK_PRIORITY		    ( 3 )
#define ADC_CONVERT_STACK_SIZE				(1024/sizeof(portSTACK_TYPE))
#define SCREEN_UPDATE_TASK_PRIORITY		    ( 2 )
#define SCREEN_UPDATE_STACK_SIZE			(1024/sizeof(portSTACK_TYPE))
// task definitions
#define TASK_MONITOR_STACK_SIZE            (1024/sizeof(portSTACK_TYPE))
#define TASK_MONITOR_STACK_PRIORITY        (tskIDLE_PRIORITY)
#define TASK_LED_STACK_SIZE                (1024/sizeof(portSTACK_TYPE))
#define TASK_LED_STACK_PRIORITY            (tskIDLE_PRIORITY)
// global
bool GpuReadToken;
bool GetGPUReadToken(void)
    if (!GpuReadToken)
        GpuReadToken=true;
    return(GpuReadToken);
void ClearGPUReadToken(void)
    GpuReadToken=false;
main.c:
    /* Create task to monitor processor activity */
    if (xTaskCreate(task_mon, "Monitor", TASK_MONITOR_STACK_SIZE, NULL,
                    TASK_MONITOR_STACK_PRIORITY, NULL) != pdPASS)
        printf("Failed to create task_mon task\r\n");
    // Create task to make led blink
    if (xTaskCreate(task_led, "Led", TASK_LED_STACK_SIZE, NULL,
                    TASK_LED_STACK_PRIORITY, NULL) != pdPASS)
        printf("Failed to create test led task\r\n");
    if (xTaskCreate(TouchParse, "TouchParse", TOUCHPARSE_STACK_SIZE, NULL,
                    TOUCHPARSE_TASK_PRIORITY, NULL) != pdPASS)
        printf("Failed to create adc_conv task\r\n");
    if (xTaskCreate(adc_conv, "ADC Convert", ADC_CONVERT_STACK_SIZE, NULL,
                    ADC_CONVERT_TASK_PRIORITY, NULL) != pdPASS)
    if (xTaskCreate(ScreenUpdate, "Screen Update", SCREEN_UPDATE_STACK_SIZE, NULL,
                    SCREEN_UPDATE_TASK_PRIORITY, NULL) != pdPASS)
        printf("Failed to create ScreenUpdate task\r\n");
-- callbacks --
void TouchParse(void *pvParameters)
    static portCHAR szList[256];
    UNUSED(pvParameters);
    for (;;)
        if (GetGPUReadToken())
            // SPI CALL
            tag_touched = Ft_Gpu_Hal_Rd32(phost, REG_TOUCH_TAG) & 0xFF;
            ClearGPUReadToken();
        // valid press
        if (tag_touched>0 && tag_touched<99)
            printf("***TP: Valid tag_touched[%i]\n\r",tag_touched);
            Play_Sound(0x23,255);
            vTaskDelay(50);
            Stop_Sound();
            vTaskDelay(450);
            sprintf(cUtilStr,"Touched [%i]\0",tag_touched);
        vTaskDelay(250);	// 250mS
void ScreenUpdate(void *pvParameters)
    for (;;)
            // SPI CALL
            BaseScreen();
        is_conversion_done = false;
        adc_start_software_conversion(ADC);
        vTaskDelay(1000);
rtel wrote on Monday, November 06, 2017:
That is always the case for a Cortex-M device. What is different
between devices is the number of interrupt priorities.
What I
Write 0xff into one of the 8-bit priority registers, then read the value
back again, that will tell you how many bits are implemented by the
device - bits that are not implemented are read back as 0. If you use
the latest head revision of FreeRTOS, from SVN, then it will do that for
you and assert() if you have it set wrong.
Questions:
1.configMAX_PRIORITIES is set to 5 in FreeRTOSConfig.h. Is this the
device?
No. It is nothing to do with the hardware.
I would recommend investing a short time in reading the free to download
FreeRTOS book. Free RTOS Book and Reference Manual
Do not edit any constants that do not start with ‘config’. Your system
is not going to work otherwise.
What do you mean by ‘scheduler execution’? Do you mean while some of
the FreeRTOS functions are executing? Or do you just mean when the RTOS
is running user tasks?
disallowed. I'm concerned however that two timer-based tasks might
I'd rather use a FreeRTOS-based token that guarantees its integrity.
Any suggestions?
My biggest suggestion is to read the book referenced above, or, as a
very minimum, some of the pages on the website.
