admbrt wrote on Thursday, September 22, 2016:
I’m working on robot controller based on Arduino Mega 2560 with alphanumeric lcd screen and 4x4 keyboard. Robot is controlled pneumatically with 8 relay dedicated board. I’m using FreeRTOS 8.2.3 port for Arduino by Phillip Stevens and Richard Berry with 4 threads running. The screen is HD44780 compatible and I use standard Arduino Liquid Crystal library for handling screen display. All threads are running perfectly fine, there are no issues with stack overfloting etc, there is just one problem with screen displaying. At the start of the program, the screen displays normally what it should display, but after some time there are errors in the displayed content or even the content is not displayed. It looks like some sort of synchronization issue or so. To avoid concurecy interrupts i suspend other threads when communicating with display, but this does not solve the problem. I conducted some tests and left the controller not connected to robot but simulating normal working conditions and there were no problems with displaying. I wonder if there is some sort of backgroud mechanism, that may have impact on communication with the screen? I’ve checked the power source and there are no voltage drops. If this is not a software issue, then faulty is the connection between board and the screen or the problem is hiddent very deep in the hardware. I ad example of display communication handling:
Screen.noBlink();
Screen.clear();
if (!movementsController->GetAutoMode()) {
#if (SUSPENDING_ALL == 1)
vTaskSuspendAll();
#if (PRIORITY_SWITCHING == 1)
vTaskPrioritySet(xTaskGetCurrentTaskHandle(), tskIDLE_PRIORITY + 4);
#if (CRITICAL_SECTION == 1)
taskDISABLE_INTERRUPTS();
Screen.println("A-Ustawienia Rozdzi.");
Screen.println("B-Ustawienia Robota");
if (splitter->GetBearingsReady()) {
Screen.println("WSAD WYKRYTY");
} else {
Screen.println("WSAD NIE WYKRYTY");
} else {
if (splitter->GetHeated()) {
PrepareScreen();
Screen.print("Cykle: ");
Screen.print(movementsController->GetCounter());
} else {
PrepareScreen();
Screen.println("NAGRZEWANIE");
Screen.println("0 - nagrzane");
Screen.setCursor(0, 2);
Screen.print("Tryb:");
if (movementsController->GetAutoMode())
Screen.print("AUTO");
Screen.print("REKA");
Screen.print(" Temp ");
Screen.print(splitter->GetTemperature());
Screen.print((char) 223);
Screen.print("C");
Screen.setCursor(14, 3);
Screen.display();
xTaskResumeAll();
vTaskPrioritySet(xTaskGetCurrentTaskHandle(), tskIDLE_PRIORITY + 3);
taskENABLE_INTERRUPTS();
After displaying, the thread waits for the notification.
