It would be nice if the “backward compatibility” defines in FreeRTOS.h would have an “#ifndef configNO_BACKWARD_COMPATIBILITY” block. This would make it easier to spot old code.
I’m using Tracealyzer 2.5.1 and noticed that
ucQueueGetQueueNumber was changed to uxQueueGetQueueNumber
Queue_t.ucQueueNumber was changed to uxQueueNumber.
I assume this will only get me into trouble if I’m using >255 queues, right?
code.
Like this? (I prefer the 'enable' rather than 'disable' otherwise its negative negative):
/* Definitions to allow backward compatibility with FreeRTOS versions
prior to V8 if desired. */
#ifndef configENABLE_BACKWARD_COMPATIBILITY
#define configENABLE_BACKWARD_COMPATIBILITY 1
#if configENABLE_BACKWARD_COMPATIBILITY == 1
#define eTaskStateGet eTaskGetState
#define portTickType TickType_t
#define xTaskHandle TaskHandle_t
#define xQueueHandle QueueHandle_t
#define xSemaphoreHandle SemaphoreHandle_t
#define xQueueSetHandle QueueSetHandle_t
#define xQueueSetMemberHandle QueueSetMemberHandle_t
#define xTimeOutType TimeOut_t
#define xMemoryRegion MemoryRegion_t
#define xTaskParameters TaskParameters_t
#define xTaskStatusType TaskStatus_t
#define xTimerHandle TimerHandle_t
#define xCoRoutineHandle CoRoutineHandle_t
#define pdTASK_HOOK_CODE TaskHookFunction_t
#define portTICK_RATE_MS portTICK_PERIOD_MS
/* Backward compatibility within the scheduler code only - these
definitions are not really required but are included for
completeness. */
#define tmrTIMER_CALLBACK TimerCallbackFunction_t
#define pdTASK_CODE TaskFunction_t
#define xListItem ListItem_t
#define xList List_t
#endif /* configENABLE_BACKWARD_COMPATIBILITY */
Yes, the data type is changing to allow more objects. As mentioned on the 'upgrading to V8' page, the trace recorder code will be updated in the final release so everything uses the same data type, in the release candidate you currently get a type mismatch as it still contains the old recorder code, which is 8 bits for that variable.
[Quoting text and including code in this forum is really hard! It has taken me several edits just to get it this good]
I just saw that FreeRTOS includes xSemaphoreCreateBinary to replace the old vSemaphoreCreateBinary function.
Maybe the old function should also be disabled by configENABLE_BACKWARD_COMPATIBILITY. It was already deprecated in 7.6.0, and should therefore be disabled in 8.0.0 (IMHO).
vSemaphoreCreateBinary() does not add any code because it is a macro, so I think it can stay to ensure the easiest possible upgrade for end users. However its actual use within demo code will be removed by replacing all calls with the function version.
I would drop the old function anyways, because they differ in semantics (taken vs. not taken after initialization, parameters) but have a very similar name. v vs. x can be overlooked easily, and may be a great source of typo-bugs!
