steverino2 wrote on Monday, January 13, 2014:
Hi all, here is a problem running FreeRTOS on an STM32F4 Discovery target using IAR EWARM toolchain.
I appreciate any ideas on how to fix it.
The project is for STM32F4 Discovery using FreeRTOS 6.1.0 / lwIP 1.3.2
It builds and runs OK on IAR EWARM 6.6.
But when I build the project with IAR EWARM 6.7 it hard faults in vTaskSwitchContext
I tried increasing heap size but did not help.
Could there be a vulnerability to the code generated by IAR EWARM 6.7 ?
I added a hard fault handler to output the register dump
[Hard fault handler]
R0 = a5a5a5a5
R1 = a5a5a5a5
R2 = 20014dcc
R3 = 200150e4
R12 = a5a5a5a5
LR [R14] = 080125e3 function call return address
PC [R15] = 08011974 program counter
PSR = a100000e
BFAR = a5a5a5b1
CFSR = 00008200
HFSR = 40000000
DFSR = 0000000b
AFSR = 00000000
SCB_SHCSR = 00000400
In the link map the fault is isolated somewhere in vTaskSwitchContext
called from portasm.o
CODE ro code 0x080125c0 0x88 portasm.o [1]
vTaskIncrementTick 0x08011853 0xc2 Code Gb tasks.o [1]
vTaskSwitchContext 0x08011915 0xe8 Code Gb tasks.o [1]
vTaskPlaceOnEventList 0x080119ff 0x5e Code Gb tasks.o [1]
noname 0x08011a5d 0x6c Code Gb tasks.o [1]
