maxgerhardt wrote on Monday, December 18, 2017:
I am currently working on integrating FreeRTOS10 with the Arduino environment (over platformio) on an Adafruit Feather M0 (ATSAMD21G18, ARM Cortex-M0+ Core, 48MHz, 256K Flash, 32K RAM). I am having problems getting the assembler instructions to compile.
I am using the port file from portable/GCC/ARM_CM0. Without any modifications, the compilation fails with following errors (gcc version 6.3.1 20170215):
arm-none-eabi-gcc -o .pioenvs/adafruit_feather_m0/lib/FreeRTOS/port.o -c -std=gnu11 -ffunction-sections -fdata-sections -Wall -mthumb -mcpu=cortex-m0plus -nostdlib --param max-inline-insns-single=500 -O1 -Wall -Wextra -DF_CPU=48000000L -DUSBCON -DPLATFORMIO=30500 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -DARDUINO_SAMD_FEATHER_M0 -D__SAMD21G18A__ -DARDUINO=10616 -DUSB_VID=0x239A -DUSB_PID=0x800B "-DUSB_PRODUCT=\"Adafruit Feather M0\"" -DUSB_MANUFACTURER=\"Adafruit\" -Ilib/FreeRTOS/src -I/home/max/.platformio/packages/framework-arduinosam/cores/adafruit -I/home/max/.platformio/packages/framework-arduinosam/system/samd/CMSIS/CMSIS/Include -I/home/max/.platformio/packages/framework-arduinosam/system/samd/CMSIS-Atmel/CMSIS/Device/ATMEL -I/home/max/.platformio/packages/framework-arduinosam/variants/feather_m0 lib/FreeRTOS/src/port.c
/tmp/cc3dVYt3.s: Assembler messages:
/tmp/cc3dVYt3.s:50: Error: cannot honor width suffix -- `mov r3,#0'
/tmp/cc3dVYt3.s:54: Error: lo register required -- `add r3,r3,#1'
/tmp/cc3dVYt3.s:86: Error: lo register required -- `sub r3,r0,#4'
/tmp/cc3dVYt3.s:87: Error: cannot honor width suffix -- `mov r4,#128'
/tmp/cc3dVYt3.s:88: Error: cannot honor width suffix -- `lsl r4,r4,#17'
/tmp/cc3dVYt3.s:90: Error: lo register required -- `sub r3,r3,#4'
/tmp/cc3dVYt3.s:92: Error: lo register required -- `sub r3,r3,#4'
/tmp/cc3dVYt3.s:95: Error: lo register required -- `sub r3,r3,#20'
/tmp/cc3dVYt3.s:97: Error: lo register required -- `sub r0,r0,#64'
/tmp/cc3dVYt3.s:125: Error: cannot honor width suffix -- `mov r2,#255'
/tmp/cc3dVYt3.s:126: Error: cannot honor width suffix -- `lsl r2,r2,#16'
/tmp/cc3dVYt3.s:127: Error: cannot honor width suffix -- `orr r2,r1'
/tmp/cc3dVYt3.s:130: Error: cannot honor width suffix -- `mov r2,#255'
/tmp/cc3dVYt3.s:131: Error: cannot honor width suffix -- `lsl r2,r2,#24'
/tmp/cc3dVYt3.s:132: Error: cannot honor width suffix -- `orr r2,r1'
/tmp/cc3dVYt3.s:135: Error: cannot honor width suffix -- `mov r3,#0'
/tmp/cc3dVYt3.s:142: Error: cannot honor width suffix -- `mov r1,#7'
/tmp/cc3dVYt3.s:149: Error: cannot honor width suffix -- `mov r0,#0'
/tmp/cc3dVYt3.s:172: Error: cannot honor width suffix -- `mov r3,#250'
/tmp/cc3dVYt3.s:173: Error: cannot honor width suffix -- `lsl r3,r3,#2'
/tmp/cc3dVYt3.s:196: Error: cannot honor width suffix -- `mov r2,#128'
/tmp/cc3dVYt3.s:197: Error: cannot honor width suffix -- `lsl r2,r2,#21'
/tmp/cc3dVYt3.s:227: Error: lo register required -- `add r2,r2,#1'
/tmp/cc3dVYt3.s:263: Error: lo register required -- `sub r3,r3,#1'
/tmp/cc3dVYt3.s:369: Error: cannot honor width suffix -- `mov r2,#128'
/tmp/cc3dVYt3.s:370: Error: cannot honor width suffix -- `lsl r2,r2,#21'
The error messages are also depended on the optimization level.
The errors stem from the function xPortPendSVHandler and vPortStartFirstTask. Once I remove the “.syntax unified” as the first line of every “asm volatile (…)” block, the errors change to
/tmp/ccR2bJjp.s: Assembler messages:
/tmp/ccR2bJjp.s:24: Error: instruction not supported in Thumb16 mode -- `adds r0,#32'
/tmp/ccR2bJjp.s:318: Error: instruction not supported in Thumb16 mode -- `subs r0,r0,#32'
/tmp/ccR2bJjp.s:335: Error: instruction not supported in Thumb16 mode -- `adds r0,r0,#16'
/tmp/ccR2bJjp.s:344: Error: instruction not supported in Thumb16 mode -- `subs r0,r0,#32'
Finally, changing “adds” to “add” and “subs” to “sub” lets the code compile. Disassembly shows
00000000 <vPortStartFirstTask>:
0: 4a0b ldr r2, [pc, #44] ; (30 <pxCurrentTCBConst2>)
2: 6813 ldr r3, [r2, #0]
4: 6818 ldr r0, [r3, #0]
6: 3020 adds r0, #32
8: f380 8809 msr PSP, r0
c: 2002 movs r0, #2
e: f380 8814 msr CONTROL, r0
12: f3bf 8f6f isb sy
16: bc3f pop {r0, r1, r2, r3, r4, r5}
18: 46ae mov lr, r5
1a: bc08 pop {r3}
1c: bc04 pop {r2}
1e: b662 cpsie i
20: 4718 bx r3
I’m writing this post for the following questions:
- Am I using the wrong compiler settings which cause the FreeRTOS provided port.c file to not compile out of the box? Is this maybe something you should fix?
- Does the generated byte code look correct?
I’ll provide project files and more infos if needed.
