Free RTOS Task Notifications
This is my first time using Task notifications and I’m having some trouble getting it to work. Below is what I have set up.
Three tasks:
Task 1, Task 2, and Task 3.
All three tasks are created at the same time.
Task 2 & 3 have osPriorityNormal and Task 1 osPriorityRealtime (from cmsis).
Task 1 finishes processing some data and then notifies the other two tasks like so:
xTaskNotify(Task_2_handle, 0, eNoAction);
xTaskNotify(Task_3_handle, 0, eNoAction);
Task 2 and 3 both have this at the start of their threads (before entering their respective infinite loops):
xTaskNotifyWait(0, 0, NULL, portMAX_DELAY);
Task 2 and 3 never receive the notification. Any idea why?
Maybe there’s a better way to prevent execution of Task 2 and 3 until Task 1 is finished with its initial processing? I’ve tried just starting Task 2 and 3 suspended and resuming them in task 1 sequentially; but that didn’t work either.
Thank you
Better (read: never ever) use suspend/resume for task synchronization.
Task notifications are fine and are designed for purposes or use cases like yours and you’ve chosen a good approach.
Also your code looks ok.
Are the task handles valid ? Could you show the task creation and the task function code, too ?
Noted, thank you.
Task 1:
osThreadId task1_id;
osThreadDef(task1, task1_thread, osPriorityRealtime, 0, 256);
task1_id = osThreadCreate(osThread(task1), NULL);
Task 2:
osThreadId task2_id;
osThreadDef(task2, task2_thread, osPriorityNormal, 0, 896 );
task2_id = osThreadCreate(osThread(task2), NULL);
Task 3:
osThreadId task3_id;
osThreadDef(task3, task3_thread, osPriorityNormal, 0, 384);
task2_id = osThreadCreate(osThread(task3), NULL);
I should mention all three tasks are/have been working fine. I just discovered a race condition with the execution of the three and decided to do this to rectify that.
I actually just noticed that this triggers the following assert in tasks.c:
configASSERT( listLIST_ITEM_CONTAINER( &( pxTCB->xEventListItem ) ) == NULL );
Looks like it occurs when notifying Task 3.
I think the assert comes from a memory corruption of FreeRTOS internal data.
Very often memory corruptions are caused by stack overflows.
Did you enable stack checking for development ?
Or just retry your application with increased stack sizes.
For instance using printf family functions required relatively large stacks.
Turns out I was notifying Task 3 before it had even been created. There was a separate thread in the system that creates and initializes Task 3. Problem solved.
Thanks for your help
