I’m using FreeRTOS v10.2.1 with dynamic memory allocation for task stack and tcb. But at deletion of a task the memory doesn’t get free’d.
I see that in the function prvDeleteTCP the vPortFree is only called if configSUPPORT_DYNAMIC_ALLOCATION == 1 && configSUPPORT_STATIC_ALLOCATION == 0 && portUSING_MPU_WRAPPERS == 0.
In my configuration configSUPPORT_DYNAMIC_ALLOCATION=1, configSUPPORT_STATIC_ALLOCATION=0 and portUSING_MPU_WRAPPERS=1
I do not understand that portUSING_MPU_WRAPPERS must be 0 to free the memory? What is the reason for this?
As a result, the #elif block in prvDeleteTCB should take care of freeing the memory.
#elif( tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE != 0 ) /*lint !e731 !e9029 Macro has been consolidated for readability reasons. */
/* The task could have been allocated statically or dynamically, so
check what was statically allocated before trying to free the
memory. */
if( pxTCB->ucStaticallyAllocated == tskDYNAMICALLY_ALLOCATED_STACK_AND_TCB )
/* Both the stack and TCB were allocated dynamically, so both
must be freed. */
vPortFree( pxTCB->pxStack );
vPortFree( pxTCB );
else if( pxTCB->ucStaticallyAllocated == tskSTATICALLY_ALLOCATED_STACK_ONLY )
/* Only the stack was statically allocated, so the TCB is the
only memory that must be freed. */
vPortFree( pxTCB );
/* Neither the stack nor the TCB were allocated dynamically, so
nothing needs to be freed. */
configASSERT( pxTCB->ucStaticallyAllocated == tskSTATICALLY_ALLOCATED_STACK_AND_TCB );
mtCOVERAGE_TEST_MARKER();
How are you determining that the memory is not freed?
Ah, I’m using FreeRTOS v10.1.0 and not v10.2.1 as I stated in my first post, my fault, sorry. The difference is that tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE is defined different.
After updating to v10.2.1 it works now.
I’m using heap_4.c implementation, and I’ve watched xFreeBytesRemaining decrementing if I add and delete tasks, until I get an error from pvPortMalloc() function.
