Hi
I am using freertos port for cortex-m33 with trustzone enable, I want to backtrace the task from task stack and to do so i want to understand the frame which get pushed into the task’s stack at each context switch.
Is there any details available, what frame get pushed into the stack in PendSV_Handler?
By definition, that is implemented in the port. I do not believe that for most ports, this is documented outside the source code, so I would decode that from the source, eg here:
