ophelieadveez wrote on Wednesday, April 26, 2017:
I’m working on IAR. I’m using FreeRTOS v9.0.0 on a STM32F417 microcontroller.
I encounter problems when I declare and use float variables and double variables.
The following code causes an Hardfault Handler.
void vTestTask(void *pvParameters)
for(;;)
float test;
test = (float)(0x22);
vTaskDelay(2000U);
Some details:
- I use heap 4.
- MCU frequency 16MHz
- Operating system used the systick
- FPU is activated.
- The heap is located in the RTOS_RESERVED region, which is located in the CCRAM (see the linker file above).
- The hardfault doesn’t occur when I write this code outside the task.
- The hardfault occurs when vTaskDelay function ends, so it seems it’s when the context task is restored.
Could you give me some hint please ?
Please find abovemy FreeRTOSConfig.h file and the linker file.
Regards,
Ophélie
Linker file:
/###ICF### Section handled by ICF editor, don’t touch! /
/-Editor annotation file-/
/ IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" /
/-Specials-/
define symbol ICFEDIT_intvec_start = 0x08000000;
/-Memory Regions-/
define symbol ICFEDIT_region_ROM_start = 0x08000000;
define symbol ICFEDIT_region_ROM_end = 0x080DFFFF;
define symbol ICFEDIT_region_RAM_start = 0x20000000;
define symbol ICFEDIT_region_RAM_end = 0x2001FAFF;
define symbol ICFEDIT_region_CCMRAM_start = 0x10000000;
define symbol ICFEDIT_region_CCMRAM_end = 0x1000FFFF;
/-Sizes-/
define symbol ICFEDIT_size_cstack = 0x500;
define symbol ICFEDIT_size_heap = 0x00;
/*** End of ICF editor section. ###ICF###*/
define memory mem with size = 4G;
define region ROM_region = mem:[from ICFEDIT_region_ROM_start to ICFEDIT_region_ROM_end];
define region RAM_region = mem:[from ICFEDIT_region_RAM_start to ICFEDIT_region_RAM_end];
define region CCMRAM_region = mem:[from ICFEDIT_region_CCMRAM_start to ICFEDIT_region_CCMRAM_end];
define block CSTACK with alignment = 8, size = ICFEDIT_size_cstack { };
define block HEAP with alignment = 8, size = ICFEDIT_size_heap { };
initialize by copy { readwrite };
do not initialize { section .noinit };
place at address mem:ICFEDIT_intvec_start { readonly section .intvec };
place in ROM_region { readonly };
place in CCMRAM_region { readwrite data section RTOS_RESERVED_RAM };
place in RAM_region { readwrite, block CSTACK, block HEAP};
FreeRTOSCongig.h:
#ifdef __ICCARM__
#include "system_stm32f4xx.h"
extern void assert_failed(uint8_t* file, uint32_t line); /* Function prototype defined in errorUtils.h */
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 1
#define configUSE_TICKLESS_IDLE 1
#define configEXPECTED_IDLE_TIME_BEFORE_SLEEP 5
#define configCPU_CLOCK_HZ SystemCoreClock
#define configTICK_RATE_HZ 100
#ifdef NDEBUG
/* TODO : remove NDEBUG once we have real board : if we remove it we lost debug, but with right SWD connection it should work */
#define configSYSTICK_CLOCK_HZ SystemCoreClock/8
#define configMAX_PRIORITIES 10
#define configMINIMAL_STACK_SIZE 128
#define configMAX_TASK_NAME_LEN 16
#define configUSE_TASK_NOTIFICATIONS 1
#define configUSE_MUTEXES 1
#define configUSE_RECURSIVE_MUTEXES 0
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_ALTERNATIVE_API 0 /* Deprecated! */
#define configQUEUE_REGISTRY_SIZE 40
#define configUSE_QUEUE_SETS 1
#define configUSE_TIME_SLICING 0
#define configUSE_NEWLIB_REENTRANT 0
#define configENABLE_BACKWARD_COMPATIBILITY 1
#define configNUM_THREAD_LOCAL_STORAGE_POINTERS 5
#define configUSE_APPLICATION_TASK_TAG 0
/* Memory allocation related definitions. */
#define configSUPPORT_STATIC_ALLOCATION 0
#define configSUPPORT_DYNAMIC_ALLOCATION 1
#define configTOTAL_HEAP_SIZE (17 * 1024)
#define configAPPLICATION_ALLOCATED_HEAP 1
/* Hook function related definitions. */
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#ifndef NDEBUG
#else
#define configCHECK_FOR_STACK_OVERFLOW 0
#define configUSE_MALLOC_FAILED_HOOK 0
#define configUSE_DAEMON_TASK_STARTUP_HOOK 0
/* Run time and task stats gathering related definitions. */
#define configGENERATE_RUN_TIME_STATS 0
#define configUSE_TRACE_FACILITY 0
#define configUSE_STATS_FORMATTING_FUNCTIONS 0
/* Co-routine related definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES 2
/* Software timer related definitions. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY 5
#define configTIMER_QUEUE_LENGTH 5
#define configTIMER_TASK_STACK_DEPTH configMINIMAL_STACK_SIZE
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 15
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt nesting behaviour configuration. */
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __NVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4 /* 15 priority levels - __NVIC_PRIO_BITS value is 4 */
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Define to trap errors during development. */
#define configASSERT( x ) if( ( x ) == 0 ) { assert_failed(__FILE__, __LINE__); }
/* Optional functions - most linkers will remove unused functions anyway. */
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_xResumeFromISR 1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 1
#define INCLUDE_xTaskGetCurrentTaskHandle 1
#define INCLUDE_uxTaskGetStackHighWaterMark 0
#define INCLUDE_xTaskGetIdleTaskHandle 0
#define INCLUDE_eTaskGetState 0
#define INCLUDE_xEventGroupSetBitFromISR 1
#define INCLUDE_xTimerPendFunctionCall 0
#define INCLUDE_xTaskAbortDelay 0
#define INCLUDE_xTaskGetHandle 0
#define INCLUDE_xTaskResumeFromISR 1
