Hello all,
I’m working on a project where I port some code to RpiZero and Rpi4. I execute some model simulations on tasks. To this point, I was using a seperate uart task to verify my outputs. I’ve been considering to use the SD card in a way that I create a file on it and write model outputs to it. The problem is, I don’t know where to start. There are two main repositories for FreeRTOS+FAT support, I am not sure what part of it I should add to my project, both of the projects seems too big and complicated. I’ve checked FatFs, seems quiet simple, but I’m missing low level disk I/O for raspberry boards.
In short, I need some pointers and hints on where to begin. There quiet good experts on the forum, any help is appreciated.
Thanks in advance,
Regards,
S.
