system
(system)
June 5, 2017, 4:39pm
1
sonycman wrote on Monday, June 05, 2017 :
Hello.
The ff_filelength() function incorrectly interprets big files (>2GB) length as error and returns zero.
This is because it uses MSB of the length value returned by FF_FileSize() as an error flag, which in case of the big files leads to misinterpretation of correct value as an erratic.
Regards
Vladimir.
htibosch
(Hein Tibosch)
June 6, 2017, 8:38am
2
heinbali01 wrote on Tuesday, June 06, 2017 :
Vladimir, this is indeed something to be finished: files longer than 2 GB.
Throughout the library, signed 32-bit values are used to indicate the length, and negative values are interpreted as an error.
lseek also has an intrinsic problem:
long lseek(int fd, long offset, int whence);
FreeRTOS+TCP is using the same syntax for ff_fseek().
The Posix varian is ok, if off_t is a 64-bit signed integer:
off_t lseek(int fd, off_t offset, int whence);
The +FAT library will not force people to include 64-bit arithmetic.
Right now I have a 2 GB file ( -2,147,483,648 bytes ) on an SD-card and I will test it. To be continued.
system
(system)
June 6, 2017, 11:28am
3
sonycman wrote on Tuesday, June 06, 2017 :
Hello, Hein
Thanks for an explanation.
I understand, that big files support is not so important for the embedded systems.
Its not needed in my case too.
But glad to hear such a support might be available one day in the future
htibosch
(Hein Tibosch)
June 6, 2017, 3:43pm
4
All right, I made some minor changes: ff_filelength() will return correct values for files between 0 bytes and 4 GB.
A return value of 0 can mean two things: the size is either 0, or the handle is invalid.
size_t uxLength;
/* Clear errno. */
stdioSET_ERRNO( 0 );
uxLength = ff_filelength( pxFile );
if( ( uxLength != 0 ) || ( stdioGET_ERRNO() == 0 ) )
/* Length equals to uxLength. */
/* Invalid handle. */
Also I introduced a new low-level function that splits up the result and the file length:
/* Use the following function in case files may get larger than 2 GB. */
int32_t FF_GetFileSize( FF_FILE *pFile, uint32_t *pulSize );
And more importantly: FF_Seek() now works correctly with sizes and offsets larger than 2GB.
Here below I attach 3 files, which are a copy of the ‘160919’ release along with mentioned changes.
ff_file.c
ff_stdio.c
include/ff_file.h
Hein Tibosch
system
(system)
June 7, 2017, 1:38am
5
sonycman wrote on Wednesday, June 07, 2017 :
Thanks a lot, Hein!
This is the best support I have ever seen!
My respects!
