philip-karlsson wrote on Friday, December 21, 2018:
Hi, we have recently tried to update our compiler at work but we are having some difficulties with getting the project to link. It appears that the ldr:s in source/portable/GCC/ARM_CM4F/port.c
static void prvPortStartFirstTask( void )
__asm volatile(
" ldr r0, =0xE000ED08 \n" /* Use the NVIC offset register to locate the stack. */
" ldr r0, [r0] \n"
" ldr r0, [r0] \n"
" msr msp, r0 \n" /* Set the msp back to the start of the stack. */
" cpsie i \n" /* Globally enable interrupts. */
" cpsie f \n"
" dsb \n"
" isb \n"
" svc 0 \n" /* System call to start first task. */
" nop \n");
and
static void vPortEnableVFP( void )
__asm volatile (
" ldr.w r0, =0xE000ED88 \n" /* The FPU enable bits are in the CPACR. */
" ldr r1, [r0] \n"
" \n"
" orr r1, r1, #( 0xf << 20 ) \n" /* Enable CP10 and CP11 coprocessors, then save back. */
" str r1, [r0] \n"
" bx r14 ");
Gets a too long PC relative offset when building with -flto. For some reason the literal pool ends up too far away from the instruction. I propose that .ltorg directives are placed at the end of each function in order to explicitly declare the literal pool straight after the epilogue:
__asm volatile(
" ldr r0, [r0] \n"
" ldr r0, [r0] \n"
" cpsie f \n"
" dsb \n"
" isb \n"
" nop \n"
" .ltorg \n"); /* Ensure a literal pool for the first ldr in range when using lto */
__asm volatile (
" ldr r1, [r0] \n"
" \n"
" str r1, [r0] \n"
" bx r14 \n"
" .ltorg "); /* Ensure a literal pool for the first ldr in range when using lto */
With these changes, the project links and when looking at the generated machine code the PC relative load is within ~20 bytes.
Kind regrads,
Philip
