I am using STM32F446RE (CM4F) and STM32CubeIDE to generate project (without CMSIS RTOS Interface by manually brining files to the Project). I want to know how to handle void SysTick_Handler(void) while compiling the project?
If you just want the systick to be used by FreeRTOS then you need to install xPortSysTickHandler as the handler for the systick interrupt. That can be done by editing the vector table to replace SysTick_Handler() with xPortSysTickHandler, or by #defineing xPortSysTickHandler to SysTick_Handler in FreeRTOSConfig.h (as described under question 1 " The application I created compiles, but does not run" on this page: https://www.freertos.org/FAQHelp.html)
