tomdtx wrote on Tuesday, October 09, 2012:
Using v7.2.0, it looks like there are an extra 8 bytes added for every pvPortMalloc call due to the computation of heapSTRUCT_SIZE. This is true for heap_2 and heap_4. Currently,
static const unsigned short heapSTRUCT_SIZE = ( sizeof( xBlockLink ) + portBYTE_ALIGNMENT - ( sizeof( xBlockLink ) % portBYTE_ALIGNMENT ) );
and in my case of a Cortex-M4 and a Keil compiler, portBYTE_ALIGNMENT is 8, and sizeof(xBlockLink) is 8. This line of code results in a heapSTRUCT_SIZE of 16 when the actual structure size is already on an 8 byte boundary. Would it be better to do something like,
static const unsigned short heapSTRUCT_SIZE = (sizeof(xBlockLink) & portBYTE_ALIGNMENT_MASK)?
(sizeof(xBlockLink) + (portBYTE_ALIGNMENT - (sizeof(xBlockLink) & portBYTE_ALIGNMENT_MASK))):
(sizeof(xBlockLink));
