I’m working on STM32WB55, with CMISV2.
I have on interrupt set by a GPIO PA2 with a priority of 8.
I have task at priority of 2 who waiting an event.
The event is set when PA2 rising UP.
The problem is xEventGroupWaitBits never trig in my task.
I’ve made some test and he trigerred when is an another task who set the event.
I don’t understand why is not triggered on the interruption.
I don’t know if it’s a configuration error, or priority issue …
Some of my code :
#define COM_EVENT_READY 1
#define COM_EVENT_NOT_READY 2
#define COM_EVENT_GROUPE ( COM_EVENT_READY \
| COM_EVENT_NOT_READY)
void COM_init(void)
// Initialisation de la communication SPI entre les microcontroleur
COM_spi_drv_init();
COM_events = xEventGroupCreate();
if(COM_events == NULL)
Error_Handler();
if(xTaskCreate (COM_mdw_task_SPINew, "SPI_TH", 256, NULL, 2, NULL) != 1)
// if(xTaskCreate (COM_mdw_task_Test, "TEST", 256, NULL, 15, NULL) != 1)
void HAL_GPIO_EXTI_Callback (uint16_t GPIO_Pin)
switch(GPIO_Pin)
case ITR_SPI_READY_Pin: //GPIO_PIN_2
GPIO_PinState state = HAL_GPIO_ReadPin(ITR_SPI_READY_GPIO_Port, ITR_SPI_READY_Pin);
if(state == GPIO_PIN_SET)
COM_mdw_masterReady();
COM_mdw_masterNotReady();
break;
default:
break;
void COM_mdw_masterReady(void)
if(COM_events != NULL)
portBASE_TYPE pxHigherPriorityTaskWoken = pdFALSE;
if (xEventGroupSetBitsFromISR (COM_events, COM_EVENT_READY, &pxHigherPriorityTaskWoken) != pdFAIL)
portYIELD_FROM_ISR (pxHigherPriorityTaskWoken);
void COM_mdw_masterNotReady(void)
if (xEventGroupSetBitsFromISR (COM_events, COM_EVENT_NOT_READY, &pxHigherPriorityTaskWoken) != pdFAIL)
void COM_mdw_task_SPINew(void *params)
(void)params;
EventBits_t events;
const TickType_t xTicksToWait = 1500 / portTICK_PERIOD_MS;
while(1)
events = xEventGroupWaitBits (COM_events, COM_EVENT_GROUPE, pdTRUE, pdFALSE, xTicksToWait);
__asm("nop");
if ((events & COM_EVENT_READY) != 0)
MAP_write_Q1(Q1_LED_LEXAN_LOCAL_INDEX,1);
if ((events & COM_EVENT_NOT_READY) != 0)
MAP_write_Q1(Q1_LED_LEXAN_LOCAL_INDEX,0);
// if(events == 0)
// xEventGroupSetBits(COM_events,COM_EVENT_READY);
I will be glad if someone can help me.
Olivier
