dutchuncle wrote on Tuesday, January 16, 2007:
Practical and philosophical issues of Event Flag Groups
Rather than making this a feature request, I’m working on a contribution, and hitting a snag.
Background: Event Flags are typically implemented as bitwise flags in a portBASE_TYPE. The flags may be set by any process that has the group’s handle, in any combination (essentially a bitwise OR). More importantly, the group may be waited on by multiple processes at once, ALL OF WHOM see the flag post(s) simultaneously (and atomically). This is very different from a queue or semaphore. When an empty queue is written, ONLY the highest-priority process waiting on that queue gets the data; when a flag is posted, ALL of the processes wating on that flag are readied (though of course they get the opportunity to run in priority order). This is complicated by the operations provided for waiting on flags: the process can specify a 32-bit mask and a code indicating whether ALL of the bits must match or ANY of the bits are sufficient, and in some systems whether the bits should be atomically cleared after a successful match - though as stated clearing by one process does NOT interfere with another pending process “seeing” the bits for its own readiness test.
FreeRTOS queues are implemented by activating the highest priority task on the event list, with all queue manipulation being done in the context of the task. The problem with doing this for flags is that the processes would run in priority order with cascading effects, rather than the atomic operations required. Besides, unlike queues which typically have one consumer waiting, flags are designed to have multiple processes awaiting different combinations of flags. (In a VRTX application, we had a dozen processes waiting with masks which mostly had different conditions and *all* had two common bits for STOP and RESET.) It would be inefficient to wake up all of the processes, perform all of the context switches, and let them all test for readiness (and probably suspend again) in context; instead, efficiency suggests performing the masking by scanning the waiting-event-list within the flag-post routine to decide which process(es) to awaken. That means the mask and operation-code isn’t kept in the context stack, and it’s per-process, so it makes sense to put it in the process control structure. BUT in good structured style, richardbarry has hidden the process structure inside the tasks.c module along with various private functions to maintain the various process lists, which means that either (a) the masking and process-waking routine should be in tasks.c violating functional separation, or (b) tasks.c should provide accessor and setting functions to private data along with whatever new function is needed to manipulate the process queue(s) incuring more overhead and complexity and *still* violating functional separation somewhat the other direction.
My own inclination is to bring the flag operation into tasks.c for efficiency, because it seems to me like keeping more privacy around the process handling, thus the lesser evil. What do other people think?
PS: The extra words could be used for different purposes, like “number to get” for queue or semaphore operations. The same issues come up if one permits “value” operations on semaphores (post N or take N where N != 1). I have seen this used to manage data-block usage where processes needed various numbers of blocks atomically for temporary or message use, and hoarding caused resource lockup. It’s an easier concept (and more efficient) than looping to get blocks and then having to unwind if there aren’t enough.
