Ethernet link-on-status on a Zynq not recognized
hannes23 wrote on Monday, January 28, 2019:
when testing exceptional conditions with the Ethernet communication on a Zynq I found out a small inconvenience.
The tested condition is: Pull the cable during an existing connection and plug it in after a while.
In ‘NetworkInterface.c’ inside prvEMACHandlerTask() it is recognized after 15 seconds, that the
cable is pulled.
The debug-message “prvEMACHandlerTask: PHY LS now 0” is written and the check-timeout is set to
a short time, 1 second.
When the cable is plugged in again and a packet is received before the ulPHYLinkStatus is read,
the timeout will be set to 15 seconds. And if then within 15 seconds a new packet is received, the
link-status will never be reset again to the correct value.
So I added a small piece of code at the place where a packet was received to solve this nasty situation:
if( xResult > 0 )
/* A packet was received. No need to check for the PHY status now,
but set a timer to check it later on. /
vTaskSetTimeOutState( &xPhyTime );
xPhyRemTime = pdMS_TO_TICKS( PHY_LS_HIGH_CHECK_TIME_MS );
xResult = 0;
If ulPHYLinkStatus was set to off previously, the status has to be checked again.
* Otherwise ulPHYLinkStatus would never be set to on, if a packet is received during timeout.
if( ( ulPHYLinkStatus & BMSR_LINK_STATUS ) == 0 )
xStatus = ulReadMDIO( PHY_REG_01_BMSR );
            if( ( ulPHYLinkStatus & BMSR_LINK_STATUS ) != ( xStatus & BMSR_LINK_STATUS ) )
                ulPHYLinkStatus = xStatus;
                FreeRTOS_printf( ( "prvEMACHandlerTask: PHY LS now %d\n", ( ulPHYLinkStatus & BMSR_LINK_STATUS ) != 0 ) );
Maybe that this problem occurs only under special conditions, which I have, and maybe that a better
code could be used, but as a fast change the addition helped.
The link off is seen after 15 seconds, and the link on is recognized immediately.
Greetings,
Johannes
heinbali01 wrote on Monday, January 28, 2019:
Hi Johannes, I’m sorry to discover that the current release of portable/NetworkInterface/Zynq/NetworkInterface.c still have this problem.
Here you find an alternative solution for the problem that you encountered.
hannes23 wrote on Tuesday, January 29, 2019:
Hi Hein,
Thanks for your reply, and sorry, that I didn’t remember your advice
regarding the patch given one year before. :slight_smile:
From: Hein Tibosch [mailto:heinbali01@users.sourceforge.net]
Sent: Monday, January 28, 2019 5:24 PM
To: [freertos:discussion] 382005@discussion.freertos.p.re.sourceforge.net
Subject: [freertos:discussion] Ethernet link-on-status on a Zynq not
recognized
Here
<https://urldefense.proofpoint.com/v2/url?u=https-3A__sourceforge.net_p_free
rtos_discussion_382005_thread_a3d9f566_-3Flimit-3D250-233ebe&d=DwMCAg&c=VlVW
iTf6NLcRnQ6UE9A3gtZ_d8K8tB_QlazTgpkF1UI&r=I8W7X9UdiYUoP79S5qYphNd5H_gskbTn2C
nU21oOZiE&m=SxdnWzQz41RCaUsUsPraD75CATB1MXw3_pD3Qe0jq50&s=yiNF8KswoFUli2Pgzf
n2ZV5WGzMxS6yd_j4CT3pfa5A&e=> you find an alternative solution for the
rtos_discussion_382005_thread_318174e2c3_-3Flimit-3D250-235ca1&d=DwMCAg&c=Vl
VWiTf6NLcRnQ6UE9A3gtZ_d8K8tB_QlazTgpkF1UI&r=I8W7X9UdiYUoP79S5qYphNd5H_gskbTn
2CnU21oOZiE&m=SxdnWzQz41RCaUsUsPraD75CATB1MXw3_pD3Qe0jq50&s=rPpzsZDdRmVr1qR1
144sYekfSMYW_5CwwFYYtUptsTU&e=>
Sent from sourceforge.net because you indicated interest in
https://sourceforge.net/p/freertos/discussion/382005/
rtos_discussion_382005_&d=DwMCAg&c=VlVWiTf6NLcRnQ6UE9A3gtZ_d8K8tB_QlazTgpkF1
UI&r=I8W7X9UdiYUoP79S5qYphNd5H_gskbTn2CnU21oOZiE&m=SxdnWzQz41RCaUsUsPraD75CA
TB1MXw3_pD3Qe0jq50&s=_4PiizdO7488QFmJdefGXMbaAyWnQ2KmaAn8EndJb98&e=>
To unsubscribe from further messages, please visit
https://sourceforge.net/auth/subscriptions/
<https://urldefense.proofpoint.com/v2/url?u=https-3A__sourceforge.net_auth_s
ubscriptions_&d=DwMCAg&c=VlVWiTf6NLcRnQ6UE9A3gtZ_d8K8tB_QlazTgpkF1UI&r=I8W7X
9UdiYUoP79S5qYphNd5H_gskbTn2CnU21oOZiE&m=SxdnWzQz41RCaUsUsPraD75CATB1MXw3_pD
3Qe0jq50&s=zMXmNww2kXjVOBal8bwJ4r-L0hlooAShiEGzCMeG8vY&e=>
