madvin
1
While I’m running this specific task, sometimes it works fine but sometimes it reboots continuously.
Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0).
Core 0 register dump:
PC : 0x4008b56c PS : 0x00060634 A0 : 0x8008b2e5 A1 : 0x3ffb5da0
0x4008b56c: block_data_size at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/heap/multi_heap.c:163
A2 : 0x00001960 A3 : 0x3ffbfb94 A4 : 0xfffffffc A5 : 0x3ffb8040
A6 : 0x40083998 A7 : 0x3ffd2bd8 A8 : 0x00001964 A9 : 0x3ffb8040
0x40083998: esp_phy_common_clock_enable at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/esp_wifi/src/phy_init.c:193
A10 : 0x3ffb5fbc A11 : 0x00060023 A12 : 0x00060023 A13 : 0x3ffbfea8
A14 : 0x00000001 A15 : 0x3ffb6f14 SAR : 0x00000018 EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace:0x4008b569:0x3ffb5da0 0x4008b2e2:0x3ffb5dc0 0x40081943:0x3ffb5df0 0x40081970:0x3ffb5e10 0x4008e989:0x3ffb5e30 0x400839bd:0x3ffb5e50 0x4012fcbd:0x3ffb5e70 0x40139929:0x3ffb5ea0 0x400903d1:0x3ffb5f20
0x4008b569: block_data_size at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/heap/multi_heap.c:162
0x4008b2e2: multi_heap_malloc_impl at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/heap/multi_heap.c:440
0x40081943: heap_caps_malloc at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/heap/heap_caps.c:145
0x40081970: heap_caps_malloc_default at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/heap/heap_caps.c:187
0x4008e989: malloc at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/newlib/heap.c:32
0x400839bd: wifi_malloc at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/esp_wifi/esp32/esp_adapter.c:73
0x4012fcbd: esf_buf_alloc at ??:?
0x40139929: wdevProcessRxSucDataAll at ??:?
0x400903d1: ppTask at ??:?
ELF file SHA256: 1e2b27ebb8fb18c1
Rebooting...
aggarg
(Gaurav Aggarwal)
2
Seems like this malloc if failing: esp-afr-sdk/esp_adapter.c at 9e3992ead78da4e9c4c0c6082d719640f258d29c · espressif/esp-afr-sdk · GitHub
Would you please try to enable CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP in your sdkconfig?
madvin
3
I already have it enabled in my sdkconfig file.
CONFIG_SPIRAM_MALLOC_ALWAYSINTERNAL=16384
CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP=y
CONFIG_SPIRAM_MALLOC_RESERVE_INTERNAL=32768
CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY=y
CONFIG_SPIRAM_CACHE_WORKAROUND=y
madvin
4
Again got this similar error but at a different location.
PC : 0x4008b55b PS : 0x00060f34 A0 : 0x8008b2e5 A1 : 0x3ffebd90
0x4008b55b: block_data_size at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/heap/multi_heap.c:157
A2 : 0x3ffb8791 A3 : 0x3ffebcb0 A4 : 0xfffffffc A5 : 0x3ffb876c
A6 : 0x3ffe739c A7 : 0x00000000 A8 : 0x00000024 A9 : 0x3ffb876c
A10 : 0x3ffe7b9c A11 : 0x3ffcdd90 A12 : 0x00000000 A13 : 0x00000001
A14 : 0x00000000 A15 : 0x00000001 SAR : 0x00000008 EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000 LBEG : 0x40191c10 LEND : 0x40191c22 LCOUNT : 0x00000000
0x40191c10: read_uint32 at /home/pcblr6004/AWS/standalone/aws_fild/build/../components/depthai/src/spi_messaging.c:45 (discriminator 3)
0x40191c22: read_uint32 at /home/pcblr6004/AWS/standalone/aws_fild/build/../components/depthai/src/spi_messaging.c:55
Backtrace:0x4008b558:0x3ffebd90 0x4008b2e2:0x3ffebdb0 0x40081943:0x3ffebde0 0x40081970:0x3ffebe00 0x4008e989:0x3ffebe20 0x400e8118:0x3ffebe40 0x400e8185:0x3ffebe70 0x400dff03:0x3ffebeb0
0x4008b558: block_data_size at /home/pcblr6004/AWS/standalone/aws_fild/build/../freertos/vendors/espressif/esp-idf/components/heap/multi_heap.c:156
0x400e8118: dai::SpiApi::req_metadata(dai::Metadata*, char const*) at /home/pcblr6004/AWS/standalone/aws_fild/build/../components/depthai/src/spi_api.cpp:576
0x400e8185: dai::SpiApi::req_message(dai::Message*, char const*) at /home/pcblr6004/AWS/standalone/aws_fild/build/../components/depthai/src/spi_api.cpp:655
0x400dff03: run_demo at /home/pcblr6004/AWS/standalone/aws_fild/build/../components/cpp/src/app_main.cpp:72
ELF file SHA256: 62d826df17a12925
Rebooting...
aggarg
(Gaurav Aggarwal)
5
None of the code in this call-stack is from us. I would recommend asking on Espressif forum.
madvin
6
Oh okay, will do that. Thanks for the support.
dacattack
(Dacattack)
7
Did you get to solve it? Please I’m having a similar issue.
