wbasser75 wrote on Thursday, October 08, 2009:
I do not set any thumb or thumb interworking flags yet I get errors on linking indicated the problem. I have attached a file with the captured build commands and link commands? Any help would be appreciated.
----- begin -----
arm-elf-gcc (GCC) 4.1.1 (WinARM)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C (ARM-only): processctl.c
arm-elf-gcc -c
-mcpu=arm7tdmi
-I.
-g
-DROM_RUN
-DGCC_ARM7
-DUSE_FREE_RTOS
-Os
-Wall
-Wextra
-Wshadow
-Wpointer-arith
-Wbad-function-cast
-Wcast-align
-Wsign-compare
-Waggregate-return
-Wreturn-type
-Wstrict-prototypes
-Wmissing-prototypes
-Wmissing-declarations
-Wunused
-fomit-frame-pointer
-fno-strict-aliasing
-std=gnu99
-I/Cyber/SfwLibraries/arm7
-I/Cyber/SfwLibraries/arm7/LPC21xx
-I/Cyber/SfwLibraries/DevHandlers/arm7/LPC21xx
-I/Cyber/SfwLibraries/Utilities
-I/FreeRTOS/Source/include
-I/Cyber/SfwLibraries/FreeRTOS/LPC21xx
-MD
-MP
-MF
.dep/processctl.o.d
processctl.c
-o processctl.o
Linking: ProcessControl.elf
arm-elf-gcc
-mcpu=arm7tdmi
-I.
-g
-DROM_RUN
-DGCC_ARM7
-DUSE_FREE_RTOS
-Os
-Wall
-Wextra
-Wshadow
-Wpointer-arith
-Wbad-function-cast
-Wcast-align
-Wsign-compare
-Waggregate-return
-Wreturn-type
-Wstrict-prototypes
-Wunused
-std=gnu99
processctl.o
/Cyber/SfwLibraries/DevHandlers/arm7/LPC21xx/sysconf.o
/Cyber/SfwLibraries/DevHandlers/arm7/LPC21xx/tm0hand.o
/Cyber/SfwLibraries/DevHandlers/arm7/LPC21xx/vichand.o
/FreeRTOS/Source/list.o
/FreeRTOS/Source/queue.o
/FreeRTOS/Source/tasks.o
/Cyber/SfwLibraries/FreeRTOS/LPC21xx/port.o
/FreeRTOS/Source/portable/MemMang/heap_2.o
-nostartfiles
/Cyber/SfwLibraries/arm7/LPC21xx/crt0.o
-Xlinker
-oProcessControl.elf
-Xlinker
-M
-Xlinker
-Map=ProcessControl.map
G:\Cyber\ProcessController\ctl\sfw>make >make.txt
processctl.c: In function ‘LedTask’:
processctl.c:150: warning: statement with no effect
c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1/…/…/…/…/arm-elf/bin/ld.exe:
Warning: /Cyber/SfwLibraries/arm7/LPC21xx/crt0.o does not support interworking,
whereas ProcessControl.elf does
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_udivsi3.o) do
es not support interworking, whereas ProcessControl.elf does
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_dvmd_tls.o) d
oes not support interworking, whereas ProcessControl.elf does
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_addsubdf3.o)
does not support interworking, whereas ProcessControl.elf does
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_muldivdf3.o)
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_fixunsdfsi.o)
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1/…/…/…/…/arm-elf/lib
\libg.a(memcpy.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(memset.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(sprintf.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(strcat.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(strncpy.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(vfprintf.o) does not support interworking, whereas ProcessControl.elf do
es
\libg.a(wcrtomb.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(wcsrtombs.o) does not support interworking, whereas ProcessControl.elf d
oes
\libg.a(wctomb_r.o) does not support interworking, whereas ProcessControl.elf do
es
\libg.a(wsetup.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(dtoa.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(fflush.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(findfp.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(freer.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(fvwrite.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(fwalk.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(impure.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(locale.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(makebuf.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(mallocr.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(memchr.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(memmove.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(mlock.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(mprec.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(reallocr.o) does not support interworking, whereas ProcessControl.elf do
es
\libg.a(s_isinf.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(s_isnan.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(stdio.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(strcmp.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(strlen.o) does not support interworking, whereas ProcessControl.elf does
\libg.a(callocr.o) does not support interworking, whereas ProcessControl.elf doe
s
\libg.a(fclose.o) does not support interworking, whereas ProcessControl.elf does
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_divsi3.o) doe
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_umodsi3.o) do
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_modsi3.o) doe
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_cmpdf2.o) doe
Warning: c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1\libgcc.a(_fixdfsi.o) do
/FreeRTOS/Source/tasks.o(vTaskSuspendAll): warning: interworking not enabled.
first occurrence: /FreeRTOS/Source/portable/MemMang/heap_2.o: thumb call to ar
m
/FreeRTOS/Source/portable/MemMang/heap_2.o: In function `pvPortMalloc’:
heap_2.c:(.text+0xe): warning: internal error: dangerous error
/FreeRTOS/Source/tasks.o(xTaskResumeAll): warning: interworking not enabled.
m
heap_2.c:(.text+0x186): warning: internal error: dangerous error
m
/FreeRTOS/Source/portable/MemMang/heap_2.o: In function `vPortFree’:
heap_2.c:(.text+0x1e2): warning: internal error: dangerous error
m
heap_2.c:(.text+0x228): warning: internal error: dangerous error
/Cyber/SfwLibraries/arm7/LPC21xx/crt0.o: In function `abort’:
/Cyber/SfwLibraries/arm7/LPC21xx/crt0.S:165: undefined reference to `_data’
c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1/…/…/…/…/arm-elf/lib\libg.a(f
reer.o): In function `_malloc_trim_r’:
mallocr.c:(.text+0x48): undefined reference to `_sbrk_r’
mallocr.c:(.text+0x64): undefined reference to `_sbrk_r’
mallocr.c:(.text+0x84): undefined reference to `_sbrk_r’
c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1/…/…/…/…/arm-elf/lib\libg.a(m
akebuf.o): In function `__smakebuf’:
makebuf.c:(.text+0x3c): undefined reference to `_fstat_r’
makebuf.c:(.text+0x110): undefined reference to `isatty’
allocr.o): In function `_malloc_r’:
mallocr.c:(.text+0x424): undefined reference to `_sbrk_r’
mallocr.c:(.text+0x4cc): undefined reference to `_sbrk_r’
c:/winarm-20060606/bin/…/lib/gcc/arm-elf/4.1.1/…/…/…/…/arm-elf/lib\libg.a(s
tdio.o): In function `__sclose’:
stdio.c:(.text+0xc): undefined reference to `_close_r’
tdio.o): In function `__sseek’:
stdio.c:(.text+0x30): undefined reference to `_lseek_r’
tdio.o): In function `__swrite’:
stdio.c:(.text+0x84): undefined reference to `_lseek_r’
stdio.c:(.text+0xac): undefined reference to `_write_r’
tdio.o): In function `__sread’:
stdio.c:(.text+0xd0): undefined reference to `_read_r’
collect2: ld returned 1 exit status
make: *** Error 1
