i’m using AWS IDT to verify my board, when i tested the FullSecureSockets,i got below log:
34208 [RunTests_task] ERROR: Failed to parse custom server certificates PK - Elliptic curve is unsupported (only NIST curves are supported)
i have following configuratin.
"name": "PKCS11",
"value": "ECC" -->device.json
"echoServerCertificateConfiguration": {
"certificateGenerationMethod": "Automatic",
"eccCurveFormat": "P224" -->userdata.json
My question is the host CA is auto-created by IDT , why the it can’t parse the certificate?
