static StaticQueue_t xStaticQueue;
I couldn’t find the data type of StaticQueue_t .
The reference of this declaration:
#include “FreeRTOS.h”
#include “queue.h”
QueueHandle_t xQueueCreateStatic( UBaseType_t uxQueueLength,
UBaseType_t uxItemSize,
uint8_t *pucQueueStorageBuffer,
StaticQueue_t *pxQueueBuffer );
rtel
(Richard Barry)
January 15, 2021, 9:39pm
2
mission
January 15, 2021, 10:29pm
3
Hi Richard,
I have done this:
#define configSUPPORT_STATIC_ALLOCATION 1
as well as this
#define configSUPPORT_STATIC_ALLOCATION CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION
The last one I got it by search engine.
None of them solved the error.
aggarg
(Gaurav Aggarwal)
January 15, 2021, 11:12pm
4
Are you sure that the correct FreeRTOSConfig.h is getting picked? In the file where you get this identifier missing error, add the following code:
#if( configSUPPORT_STATIC_ALLOCATION == 1 )
#error Test to see if static allocation is enabled.
If the above #error is triggered, then we know that configSUPPORT_STATIC_ALLOCATION is configured correctly.
Thanks aggarg.
I updated from version 8 to version 10 and I added the callback function code from FreeRTOS website. Then I was able to compile completely and the program worked as expected.
The callback function:
void vApplicationGetIdleTaskMemory(,,..){.....}
