Hello!
I am running into a problem trying to analyze task preemption in a FreeRTOS application running on MicroBlaze.
I am using Vitis 2020.2 with FreeRTOS 1.7 and freertos_hello_world.c sample app.
When I have “generate_runtime_stats” set to 0 (sets configGENERATE_RUN_TIME_STATS to 0) in the BSP OS configuration the app runs fine. However, when I do enable it (configGENERATE_RUN_TIME_STATS 1) the OS tick / timer interrupt stops working. The main symptom is that tasks block forever in vTaskDelay().
I placed a breakpoint in vPortTickISR() and it never gets hit indicating that the timer interrupt is disabled, or all interrupts are disabled.
I verified that the timer interrupt handler is installed via Xilinx API.
Has anyone here seen this or similar issue?
