Hi, guys
i try to use emwin and freeRTOS on my stm32f4 board, but i found something really wired
I found the task include emwin function(like WM_Exec(),GUI_TOUCH_Exec() or GUI_DispStringAt()) can not work with any another tasks even its empty task
but when i only run emwin task the system works fine.
i make macro GUI_OS is 1 GUI_MAXTASKis 5 emwin memory to 64k bytes
freeRTOS heap size from 90k bytes
system heap and stack size to 8k bytes
this is maximum ram i can provide but the system still not works
I’m afraid I’m not familiar with emWin so don’t know what resources it is using.
I can only suggest the normal things. Ensuring you are using a recent version of FreeRTOS with configASSERT() defined may help detect something amiss. Otherwise I can only assume that the task running emWin is consuming all the CPU time and not letting anything else run. Have you tried running the emWin task at the lowest priority, or using the trace tool to see what is going on?
i found the problem!!!
i did not replace three handlers in startup file just replace handlers like this:
void PendSV_Handler(void)
xPortPendSVHandler();
its too stupid that i thought its same.
