HELP:
I’m trying to port a working LPC54608 example to the LPC54628 mcu.
I have the RTOS working correctly with LWIP and can create threads, Queues, Semafor’s, etc.
I can get emWIN working without the RTOS on the LPC54628 dev board (OM13098).
I’m using NXP’s MCUXpresso v10 IDE with v2.5 SDK for this new mcu.
BUT
I get a forced bus fault (hard fault) in GUI_Init() when porting to use the RTOS.
The LCD init and I2C (TFT LCD) returns success.
Second, step into the offending function to see which line causes the
fault, then report back to see if we can suggest anything further (could
just be a linker script error, or something basic like that).
Thanks Richard…
I have read that doc but it never hurts to re-read it…
The function (GUI_Init()) that causes the hard fault is in the emWIN Library (libemWIN_M4F.a) and does not allow me to step into it.
I have set and used assert but I’m get nothing back from it during the LOAD_X… Ftns. They all execute without error.
There must be some way to enable internal error checking in the library ftn’s ?
Thanks Richard…
It just seems funny that it runs OK ON THE 54628 when the MCU is set to 54608 but when it is set to 54628 it fails… These 2 processors are supposed to be plug-n-play replacible…
The 54628 is just faster…
I’ll continue writting code using the older processor for now…
