bluememberosnly wrote on Tuesday, October 17, 2017:
Does FreeRTOS support the new microcontrollers from Silabs that are ARM Cortex-M4 CPU based?
rtel wrote on Tuesday, October 17, 2017:
Hi - FreeRTOS supports ALL ARM Cortex-M0/M0+/M3/M4/M4F/M7
microcontrollers from all manufacturers. That is because the FreeRTOS
implementation does not have any dependencies that are outside of the
Cortex-M core. You might have to create a project for it if there is
not a pre-configured project in the download, that’s all.
Things to note: If you are using a Cortex-M4 without an FPU then use
the Cortex-M3 port layer, and if you are using a Cortex-M7 with an R0p1
core then use the M7 port layer, otherwise use the M4F port layer.
http://www.freertos.org/Creating-a-new-FreeRTOS-project.html
http://www.freertos.org/porting-a-freertos-demo-to-different-hardware.html
