Hi all,<BR>
is OpenRTOS Viewer plugin for eclipse also usable for FreeRTOS? If yes, then what is necessary to do to get it working? I just added Task and Queue tables from this plugin, but they’re still empty…<BR><BR>
If OpenRTOS Viewer plugin is not usable for FreeRTOS, is there any other way to get information about tasks and queues?
<BR><BR>
Jan.
It should work with both FreeRTOS and OpenRTOS. However, there have been a few reports recently of problems. It might be that there are problems with particular tool configurations as unfortunately we cannot test all possible Eclipse versions - but then it could also potentially be something in FreeRTOS V6 that is causing an issue. Could you say which version of everything you are using - Eclipse, FreeRTOS and the plug-in.
