I can edit, compile and program the MCU on the LM3S6965 evaluation board. Verified by making a code change that is reflected on the display. I can’t seem to get debugging working.
Open OCD seems to be running
Info: openocd.c:92 main(): Open On-Chip Debugger (2007-08-17 11:00 CEST)
When I initiate debug session I get
Error while launching command: gdb -version
Have you installed GDB?
If you have, then try connecting to your target via the GDBs telnet interface. This usually offers better indication of what’s wrong.
