I’ve read about FreeRTOS and would like to try a small dev project to learn more. I am not a commercial
developer but experienced with electronics, breadboarding, and programming in C. I’ve built real-time systems with 8085’s in the past using the old Intel dev system and ICE but I’ve been doing other things for the past 25 yrs. I can use Eclipse.
I am happy to bootstrap my learning by duplicating some simple running system. The question is: which one is easiest to get going with?
In your view, what is the easiest, small scale hardware to implement from cold start? The Arduino Due is a Cortex-M3-based board. Would that be a useful place to start?
Could you point me to a recent step-by-step implementation documented on the web?
The Aruino Due is definitely one good option - but there are many others
good low cost options too that have free tools. For example there are
the STM32 discovery boards, MSP432
Launchpad boards, Silicon Labs starter
kits, etc.
If you go for the Due hardware then download and install Atmel Studio
too and you will probably find it is very easy to use that to program
and debug the Due board. I’m not sure if you will also need a separate
debug interface, probably not, but best to check.
If you don’t mind using a simulator instead of real hardware, then you
could start with a FreeRTOS project that runs in the Keil uVision
simulator - there are some links on the FreeRTOS.org site somewhere. If
you go that route then you will be simulating real Cortex-M hardware -
another alternative is to use a simple demo in the FreeRTOS
Windows port, but that is a separate port rather than simulating
real hardware.
