thomas84 wrote on Thursday, April 12, 2012:
I tried it and if i change the code like in your example above, i get no response from target.
This is the transmit function:
void vSendEMACTxData( unsigned short usTxDataLen )
unsigned long ulAttempts = 0UL;
/* Check to see if the Tx descriptor is free, indicated by its buffer being
NULL. */
while( TX_DESC_PACKET( emacTX_DESC_INDEX ) != ( unsigned long ) NULL )
/* Wait for the Tx descriptor to become available. */
vTaskDelay( emacBUFFER_WAIT_DELAY );
ulAttempts++;
if( ulAttempts > emacBUFFER_WAIT_ATTEMPTS )
/* Something has gone wrong as the Tx descriptor is still in use.
Clear it down manually, the data it was sending will probably be
lost. */
prvReturnBuffer( ( unsigned char * ) TX_DESC_PACKET( emacTX_DESC_INDEX ) );
break;
/* Setup the Tx descriptor for transmission. Remember the length of the
data being sent so the second descriptor can be used to send it again from
within the ISR. */
usSendLen = usTxDataLen;
TX_DESC_PACKET( emacTX_DESC_INDEX ) = ( unsigned long ) uip_buf;
TX_DESC_CTRL( emacTX_DESC_INDEX ) = ( usTxDataLen | TCTRL_LAST | TCTRL_INT );
LPC_EMAC->TxProduceIndex = ( emacTX_DESC_INDEX + 1 );
/* uip_buf is being sent by the Tx descriptor. Allocate a new buffer. */
uip_buf = prvGetNextBuffer();
and this the EMAC_ISR:
unsigned long ulStatus;
long lHigherPriorityTaskWoken = pdFALSE;
ulStatus = LPC_EMAC->IntStatus;
/* Clear the interrupt. */
LPC_EMAC->IntClear = ulStatus;
if( ulStatus & INT_RX_DONE )
/* Ensure the uIP task is not blocked as data has arrived. */
xSemaphoreGiveFromISR( xEMACSemaphore, &lHigherPriorityTaskWoken );
if( ulStatus & INT_TX_DONE )
if( usSendLen > 0 )
// Send the data again, using the second descriptor. As there are
//only two descriptors the index is set back to 0.
TX_DESC_PACKET( ( emacTX_DESC_INDEX + 1 ) ) = TX_DESC_PACKET( emacTX_DESC_INDEX );
TX_DESC_CTRL( ( emacTX_DESC_INDEX + 1 ) ) = ( usSendLen | TCTRL_LAST | TCTRL_INT );
LPC_EMAC->TxProduceIndex = ( emacTX_DESC_INDEX );
// This is the second Tx so set usSendLen to 0 to indicate that the
// Tx descriptors will be free again.
usSendLen = 0UL;
// The Tx buffer is no longer required.
TX_DESC_PACKET( emacTX_DESC_INDEX ) = ( unsigned long ) NULL;
portEND_SWITCHING_ISR( lHigherPriorityTaskWoken );
If i delete the line: TX_DESC_PACKET( ( emacTX_DESC_INDEX + 1 ) ) = TX_DESC_PACKET( emacTX_DESC_INDEX );
in the EMAC_ISR i can ping and i have only one reply, but the problem remains, that 01010101 on the cable as if the programm has to output two frames…
