Hi there,
this is follow up question from the STM32H Dual Core AMP Demo - #12 by dookei .(topic was already closed)
It relateds to the usage from the xMessageBufferCreateStaticWithCallback in dual core systems.
I used this as guide :FreeRTOS xMessageBufferCreateStatic() API documentation
For the AMP implementation when using xMessageBufferCreateStaticWithCallback
I can only define and implement the callbacks for the core that is transmitting the message. Right?
So on the core that is transmitting the message I have
xMessageBufferWithCallback = xMessageBufferCreateStaticWithCallback(
sizeof( ucMessageBufferWithCallbackStorage ),
ucMessageBufferWithCallbackStorage,
&xMessageBufferWithCallbackStruct,
vSendCompletedCallback,
vReceiveCompletedCallback );
and then the call for the vSendCompletedCallback that is going to generate the interrupt on the partner core.
void vSendCompletedCallback( MessageBufferHandle_t xUpdatedBuffer, BaseType_t xIsInsideISR, BaseType_t * const pxHigherPriorityTaskWoken )
/* Writes the handle of the data message buffer to which data was written to the control message buffer*/
while( xMessageBufferSend( xControlMsgBuff_Tx, &xUpdatedBuffer, sizeof( xUpdatedBuffer ), mbaDONT_BLOCK ) != sizeof( xUpdatedBuffer ) )
/* Nothing to do here. */
GENERATE_EXTI(EXTI_LINE_TX_DISP_SEND_COMP); /* Generate interrupt on the other core */
void vReceiveCompletedCallback( MessageBufferHandle_t xMessageBuffer, BaseType_t xIsInsideISR, BaseType_t * const pxHigherPriorityTaskWoken )
// do nothing this will be implemented by the ISR
/* Interrupt generated by the partner core when the message was read from the buffer */
void IPC_COM_ISR_Tx( void )
//TODO configASSERT( xM7AMPTask );
CLEARFLAG_EXTI(EXTI_LINE_TX_DISP_REC_COMP);
xMessageBufferReceiveCompletedFromISR( xDataMsgBuff_Tx, &xHigherPriorityTaskWoken );
/* Normal FreeRTOS "yield from interrupt" semantics, where
xHigherPriorityTaskWoken is initialized to pdFALSE and will then get set to
pdTRUE if the interrupt unblocks a task that has a priority above that of
the currently executing task. */
That means that the core that is receiving the message (and not creating the message buffer) wont have a call back since we didnt created the message buffer. Or am I missing something here ( I must
On the receiving core I have ISR that is going to notify that a message was sent to the buffer and is available to be received.
void IPC_COM_ISR_Rx(void) // interrupt generated from the partner Core to indicate a message wa sent to the buffer.
MessageBufferHandle_t xUpdatedMessageBuffer;
/* xControlMessageBuffer contains the handle of the message buffer that contains data. */
if( xMessageBufferReceiveFromISR( xControlMsgBuff_Rx, &xUpdatedMessageBuffer, sizeof( xUpdatedMessageBuffer ), &xHigherPriorityTaskWoken )
== sizeof( xUpdatedMessageBuffer ) ){
/* Call the API function that sends a notification to any task that is
blocked on the xUpdatedMessageBuffer message buffer waiting for data to
arrive. */
xMessageBufferSendCompletedFromISR( xUpdatedMessageBuffer, &xHigherPriorityTaskWoken );
/* Did sending to the queue unblock a higher priority task? */
if( xHigherPriorityTaskWoken ){
After that the blocked task will read the message buffer and (I assume) execute the default implementation from sbRECEIVE_COMPLETED( pxStreamBuffer ). Or am I missunderstanding something ?
xReceivedBytes = xMessageBufferReceive(
xDataMsgBuff_Rx, /* Handle of message buffer. */
&xReceivedMsg, /* Buffer into which received data is placed. */
sizeof( Message_IPC ), /* Size of the receive buffer. */
IPC_COM_WAIT_RX ); /* Time to wait for data to arrive. */
I would appreciate if anyone could shed some light in this topic.
Cheers
