dsPIC33EP- Project compiles but fails to Run
groschh wrote on Wednesday, July 17, 2013:
MPLAB 8.91
C30 3.31 or XC16
Testing with MPLAB Simulator
I want to port a project from dsPIC33F to dsPIC33EP256MU810.
I took care about the missing declaration of the PSVPAG and modified Linkerscript as follows:
PSVPAG       = 0x32;
_PSVPAG       = 0x32;
I declared MPLAB_DSPIC_PORT with in the Project macros and exchanged the include directive in FreeRTOSConfig.h to #include <p33Exxxx.h>.
As the silicon specifies aux-Flash it defines “__HAS_EDS__” I modified port.c  as follows:
#define portRESTORE_CONTEXT() \
asm volatile( “MOV _pxCurrentTCB, W0 \n” /* Restore the stack pointer for the task. */ \
“MOV , W15 \n” \
“POP W0 \n” /* Restore the critical nesting counter for the task. */ \
“MOV W0, _uxCriticalNesting \n” \
“POP DSWPAG \n” \
"POP DSRPAG
and _vPortYield:
PUSH CORCON
PUSH DSRPAG
push    DSWPAG
MOV _uxCriticalNesting, W0
POP     DSWPAG
POP DSRPAG
POP CORCON
So the project compiles and starts running. If reaching  vTaskDelay(10); it crashes in portYIELD_WITHIN_API();
What I found is that *pxCurrentTCB holds obviously an invalid adress and so the poped return address will lead to a wrong PC after call _vTaskSwitchContext.
Same Project compiled for dsPIC33FJ128MC804 does work fine.
As my knowledge ends at this point I want to ask you to check this behavior.
Best regards and thanks for your help in advance
Heiko
Code :
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#include <p33exxxx.h>
#define configUSE_PREEMPTION 0
#define configUSE_IDLE_HOOK 1
#define configUSE_TICK_HOOK 0
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
#define configCPU_CLOCK_HZ ( ( unsigned long ) 40000000 )  /* Fosc / 2 */
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 4 )
#define configMINIMAL_STACK_SIZE ( 200 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) 2000 )
#define configMAX_TASK_NAME_LEN ( 4 )
#define configUSE_TRACE_FACILITY 0
#define configUSE_16_BIT_TICKS 1
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 0
#define INCLUDE_uxTaskPriorityGet 0
#define INCLUDE_vTaskDelete 0
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define configKERNEL_INTERRUPT_PRIORITY 0x01
int main( void )
prvSetupHardware();
    xTaskCreate( MainTask,          (signed char*) “Main”, 300,     NULL,      Default_TASK_PRIORITY,          NULL);
/* Finally start the scheduler. */
vTaskStartScheduler();
/* Will only reach here if there is insufficient heap available to start
the scheduler. */
while(1);
return 0;
void MainTask( void *pvParameters )
    for( ;; )
   vTaskDelay(10); //–>>> Crash!
   Nop();
  Nop();
rtel wrote on Wednesday, July 17, 2013:
As you found out, EDS is not currently supported on the dsPIC.  It is supported on PIC24, and there was a reason why the same support was not extended to the dsPIC but to be honest I can’t quite remember what it was - something to do with additional registers being required though.
That is actually not necessary - the old definitions are maintained in portable.h for backward compatibility with ancient projects (including the demos in the FreeRTOS download - although V7.5.0 has MPLAB X projects for the PIC24 and dsPIC).  It won’t do any harm defining it, but its just easier to not define in and instead make sure the correct path is included in your IDEs include path.  That is, the path to the correct portmacro.h header file in FreeRTOS/source/portable/MPLAB/…
So that is good…but does not necessarily prove it is working correctly unless you have tired all combinations of placement to ensure the EDS extensions are being exercised.
Sorry - can’t do that right now, especially as this is your own code rather than supported code.  However, I can confirm that yes, there was a problem expected…somewhere.
If you sort this out please be sure to post your work to the FreeRTOS Interactive site.  Maybe you will be lucky and somebody else reading this post will have this working already.
Dear RichardBarry,
thanks for your fast reply.
if MPLAB_DSPIC_PORT is not declared, the compiler will fail to find “portRESTORE_CONTEXT()”. I can find this Macro in the source only within the defines of MPLAB_DSPIC_PORT.
Could it be that the DO Stack was the Problem as there is a Stack with four places now for DO Loops?
Well my code actually rather consists of a Main Task with an endless loop including a vTaskDelay(10); and the suggested RTOS init. Nothing else. I also tried your Demo Projects with similar modification and same result.
The Question is now, will dsPic33e Family be supported in the near future or would I have to change to another RTOS?
Is there a way to get more support regarding this matter if buying kind of professional Support Ticket or what ever?
Best regards
Heiko
You are right.  I forgot that.  It has been fixed in V7.5.0 (I think).
Probably.
In the very near future no - in the longer term I can’t say for definite as it will depend on demand.
I will come back to you on that last point.
groschh wrote on Thursday, July 18, 2013:
Richard,
you mentioned Version 7.5.0. coming up.
When will this be relaesed, do you have a prerelease version for tests?
Best
Heiko
rtel wrote on Thursday, July 18, 2013:
It will be released as soon as I have updated the documentation - in the mean time you can get it out of SVN.  It is currently the head revision and will be tagged when the zip files are released (see the “Code” menu item at the top of the SourceForge page when you are viewing this form).
If all goes well today then the .zip files may get uploaded this afternoon.
groschh wrote on Wednesday, October 09, 2013:
Richard,
hello again.
please refer to following discussion, solving for the moment the problems I had .
https://sourceforge.net/p/freertos/discussion/382005/thread/9df19af7/
best regards
Heiko
