bazhill wrote on Wednesday, August 27, 2008:
I find that when more than one task is running on a dsPIC33256GP710 the serial ports do not work and start oscillating.
The oscillation has a period of about 200us. The last 50us of the form is a negatively going triangular wave.
This is with version 5.0.2
If I use version 4.5 then I find I can have two tasks but only one can write to a serial port. If two try then I get the oscillation.
The harness is below:
#define mainCHECK_TASK_STACK_SIZE ( configMINIMAL_STACK_SIZE * 2 )
static void TestTask1( void *pvParameters )
while(1)
//SendChar1(‘A’); // non-irq char send on UART1
taskYIELD();
static void TestTask2( void *pvParameters )
while(1)
//SendChar1(‘B’);
taskYIELD();
int main()
// Get the processor going at 40MIPs
PSVPAG = 0;
CORCONbits.PSV=1;
// we have a 10MHz crystal - we want 40MIPS
PLLFBD=32; // M=40
CLKDIVbits.PLLPOST=0; // N1=2
CLKDIVbits.PLLPRE=0; // N2=2
OSCTUN=0; // Tune FRC oscillator, if FRC is used
// Disable Watch Dog Timer
RCONbits.SWDTEN=0;
// Wait for PLL to lock
while(OSCCONbits.LOCK!=1) {};
_U1TXIE = 0;
_U1RXIE = 0;
_U1RXIF = 0;
U1MODE = 0; // 8 bits no parity 16 clocks per bit
U1STA = 0; // enable transmit - non - irq driven
U1MODE = 0x8000; // 8 bits no parity 16 clocks per bit
U1STA = 0x400; // enable transmit - non - irq driven
// set the baud rate to 57600
U1BRG = 45;
_U2TXIE = 0;
_U2RXIE = 0;
_U2RXIF = 0;
U2MODE = 0; // 8 bits no parity 16 clocks per bit
U2STA = 0; // enable transmit - non - irq driven
U2MODE = 0x8000; // 8 bits no parity 16 clocks per bit
U2STA = 0x400; // enable transmit - non - irq driven
U2BRG = 45;
// Create a task
xTaskCreate( TestTask1, “t1”, mainCHECK_TASK_STACK_SIZE, NULL, 2, NULL );
xTaskCreate( TestTask2, “t2”, mainCHECK_TASK_STACK_SIZE, NULL, 3, NULL );
/* Finally start the scheduler. */
vTaskStartScheduler();
return 0;
// The idle hook
void vApplicationIdleHook( void )
/* Schedule the co-routines from within the idle task hook. */
vCoRoutineSchedule();
// put the processor to sleep
