ltran2016 wrote on Thursday, February 18, 2016:
I’m in the processing of bringing up the dsPIC DSC start kit and I think I have all my bases covered, but apparently that isn’t the case. I’ve already trawled through the discussions for any issue related to this, but it hasn’t helped. I’m loading a simple build that just blinks an LED periodically. The problem is it looks as if something keeps resetting the processor. I’m clearing the watchdog, but it doesn’t seem to have any effect.
Could someone give this a look and tell me where I might be going wrong. I’ve successfully implemented FreeRTOS on NiosII, so I’m not a newbie at this.
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#define MPLAB_DSPIC_PORT
#include <p33FJ256GP506.h>
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configTICK_RATE_HZ ((TickType_t) 1000)
#define configCPU_CLOCK_HZ ((unsigned long) 12000000) /* Fosc / 2 */
#define configMAX_PRIORITIES (4)
#define configMINIMAL_STACK_SIZE (105)
#define configTOTAL_HEAP_SIZE (( size_t ) 8192)
#define configMAX_TASK_NAME_LEN (4)
#define configUSE_TRACE_FACILITY 0
#define configIDLE_SHOULD_YIELD 0
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES (2)
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define configKERNEL_INTERRUPT_PRIORITY 0x01
// FBS
#pragma config BWRP = WRPROTECT_OFF // Boot Segment Write Protect (Boot Segment may be written)
#pragma config BSS = NO_FLASH // Boot Segment Program Flash Code Protection (No Boot program Flash segment)
#pragma config RBS = NO_RAM // Boot Segment RAM Protection (No Boot RAM)
// FSS
#pragma config SWRP = WRPROTECT_OFF // Secure Segment Program Write Protect (Secure Segment may be written)
#pragma config SSS = NO_FLASH // Secure Segment Program Flash Code Protection (No Secure Segment)
#pragma config RSS = NO_RAM // Secure Segment Data RAM Protection (No Secure RAM)
// FGS
#pragma config GWRP = OFF // General Code Segment Write Protect (User program memory is not write-protected)
#pragma config GSS = OFF // General Segment Code Protection (User program memory is not code-protected)
// FOSCSEL
#pragma config FNOSC = FRC // Oscillator Mode (Internal Fast RC (FRC))
#pragma config IESO = OFF // Two-speed Oscillator Start-Up Enable (Start up with user-selected oscillator)
// FOSC
#pragma config POSCMD = NONE // Primary Oscillator Source (Primary Oscillator Disabled)
#pragma config OSCIOFNC = ON // OSC2 Pin Function (OSC2 pin has digital I/O function)
#pragma config FCKSM = CSDCMD // Clock Switching and Monitor (Both Clock Switching and Fail-Safe Clock Monitor are disabled)
// FWDT
#pragma config WDTPOST = PS32768 // Watchdog Timer Postscaler (1:32,768)
#pragma config WDTPRE = PR128 // WDT Prescaler (1:128)
#pragma config WINDIS = OFF // Watchdog Timer Window (Watchdog Timer in Non-Window mode)
#pragma config FWDTEN = OFF // Watchdog Timer Enable (Watchdog timer enabled/disabled by user software)
// FPOR
#pragma config FPWRT = PWR8 // POR Timer Value (8ms)
// FICD
#pragma config ICS = PGD1 // Comm Channel Select (Communicate on PGC1/EMUC1 and PGD1/EMUD1)
#pragma config JTAGEN = OFF // JTAG Port Enable (JTAG is Disabled)
LED *LED_Init (SYS_INT_t period, SYS_INT_t set_task_priority, SYS_INT_t clr_task_priority) {
// allocate led space
LED *pLED = (LED *)(pvPortMalloc (sizeof(LED)));
// exit if space couldn't be allocated
if (pLED == NULL) return NULL;
// initialize yellow led port pin
PORT_BIT_TRI(C,13) = 0;
PORT_BIT_LAT(C,13) = 0;
// initialize red led port pin
PORT_BIT_TRI(C,14) = 0;
PORT_BIT_LAT(C,14) = 0;
// initialize green led port pin
PORT_BIT_TRI(C,15) = 0;
PORT_BIT_LAT(C,15) = 0;
// set heart beat period
LED_HEARTBEAT_PERIOD = period;
// allocate led messeging queue, start task if queue space allocated
LED_QUEUE = xQueueCreate (32, sizeof(LED_MSG));
if (LED_QUEUE != NULL) {
// led gateway clear control task
xTaskCreate (
LED_Clr_Task,
"LedClear",
32,
(void *)pLED,
clr_task_priority,
NULL);
return pLED;
static void LED_Clr_Task (void *pvParam) {
//LED *pLED = (LED *)pvParam;
U32 idx;
portTickType xLastWakeTime;
// get initial wake count, next hearbeat time
xLastWakeTime = xTaskGetTickCount ();
//xHeartBeatTime = xLastWakeTime + (portTickType)LED_HEARTBEAT_PERIOD;
// task loop
for (;;) {
// wait 100 ticks
vTaskDelay (100);
// clear watchdog timer
ClrWdt();
PORT_BIT_LAT(C,15) = ~PORT_BIT_LAT(C,15); // toggle pin (amber LED on demo board DM330011)
// wait 100 ticks
vTaskDelay (100);
ClrWdt();
vTaskDelayUntil (&xLastWakeTime, 300);
ClrWdt();
// delete task when complete
vTaskDelete(NULL);
