leviatan1 wrote on Saturday, May 03, 2014:
Hello, i am trying to get one simple project in FreeRTOS with a dsP30f4013 and when i build it i get this Output:
Debug build of project D:\TESIS\PROYECTO MICRO\Project1\dsP30v_1.mcp' started. Language tool versions: pic30-as.exe v3.31, pic30-gcc.exe v3.31, pic30-ld.exe v3.31, pic30-ar.exe v3.31 Preprocessor symbol __DEBUG’ is defined.
Sat May 03 20:31:13 2014
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\croutine.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\event_groups.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\list.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\queue.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\tasks.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\timers.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\port.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\portasm_dsPIC.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\main.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\heap_1.o” is up to date.
Make: The target “D:\TESIS\PROYECTO MICRO\Project1\dsP30v_1.cof” is out of date.
Executing: “C:\Program Files (x86)\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=30F4013 “croutine.o” “event_groups.o” “list.o” “queue.o” “tasks.o” “timers.o” “port.o” “portasm_dsPIC.o” “main.o” “heap_1.o” -o"dsP30v_1.cof" -Wl,-L"C:\Program Files (x86)\Microchip\MPLAB C30\lib",-L"C:\Program Files (x86)\Microchip\MPLAB C30\lib\dsPIC30F",–script=“p30F4013.gld”,–defsym=__MPLAB_BUILD=1,–defsym=__MPLAB_DEBUG=1,-Map=“dsP30v_1.map”,–report-mem
Program Memory [Origin = 0x100, Length = 0x7efe]
section address length (PC units) length (bytes) (dec)
.text 0x100 0xa6 0xf9 (249)
.const 0x1a6 0x26 0x39 (57)
.text 0x1cc 0x17f8 0x23f4 (9204)
.dinit 0x19c4 0x40 0x60 (96)
.text 0x1a04 0xa 0xf (15)
Total program memory used (bytes): 0x2595 (9621) 19%
Data Memory [Origin = 0x800, Length = 0x800]
section address alignment gaps total length (dec)
.nbss 0x800 0 0x47a (1146)
.ndata 0xc7a 0 0x22 (34)
Total data memory used (bytes): 0x49c (1180) 57%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0xc9c 0x364 (868)
Maximum dynamic memory (bytes): 0x364 (868)
tasks.o(.text+0x7e4): In function prvIdleTask': D:\TESIS\PROYECTO MICRO\FreeRTOS\Source\tasks.c:2603: undefined reference to vApplicationIdleHook’
tasks.o(.text+0xd8): In function xTaskGenericCreate': D:\TESIS\PROYECTO MICRO\FreeRTOS\Source\tasks.c:676: undefined reference to vPortYield’
tasks.o(.text+0xda):D:\TESIS\PROYECTO MICRO\FreeRTOS\Source\tasks.c: undefined reference to vPortYield' tasks.o(.text+0x150): In function vTaskDelayUntil’:
D:\TESIS\PROYECTO MICRO\FreeRTOS\Source\tasks.c:860: undefined reference to vPortYield' tasks.o(.text+0x152):D:\TESIS\PROYECTO MICRO\FreeRTOS\Source\tasks.c: undefined reference to vPortYield’
tasks.o(.text+0x184): In function vTaskDelay': D:\TESIS\PROYECTO MICRO\FreeRTOS\Source\tasks.c:926: undefined reference to vPortYield’
tasks.o(.text+0x186):D:\TESIS\PROYECTO MICRO\FreeRTOS\Source\tasks.c: more undefined references to `vPortYield’ follow
Link step failed.
Debug build of project D:\TESIS\PROYECTO MICRO\Project1\dsP30v_1.mcp' failed. Language tool versions: pic30-as.exe v3.31, pic30-gcc.exe v3.31, pic30-ld.exe v3.31, pic30-ar.exe v3.31 Preprocessor symbol __DEBUG’ is defined.
Sat May 03 20:31:14 2014
BUILD FAILED
HOW CAN I GET THESE ERRORS GONE? THANK you very much
