leviatan1 wrote on Monday, June 23, 2014:
Hello, i managed to compile my code for my dsp30f project as follows:
main.c
xQueueHandle Queue_I2C_DataHander=0x0000;
xQueueHandle Queue_I2C_ACK=0x0000;
/******************Semaphores and Task Handles****************/
xSemaphoreHandle Mutex_I2C_Rx =0;
xSemaphoreHandle Mutex_I2C_Tx=0;
xSemaphoreHandle Mutex_I2C_Ctrl=0;
xTaskHandle I2C_HANDLE;
int main( void )
/* Create the standar Queues*/
Queue_I2C_DataHander = xQueueCreate(3, sizeof(unsigned short));
Queue_I2C_ACK = xQueueCreate(3, sizeof(unsigned short));
/* Create standard Semaphores and Mutexes*/
Mutex_I2C_Rx = xSemaphoreCreateMutex();
Mutex_I2C_Tx = xSemaphoreCreateMutex();
Mutex_I2C_Ctrl= xSemaphoreCreateMutex();
/* Create the standard tasks. */
xTaskCreate(prep_HARD,"Config Hardware",100,NULL,6,NULL);
xTaskCreate(data_I2C_HANDLE,"Handle I2C",100,NULL,4,&I2C_HANDLE);
xTaskCreate(rx_I2C,"Recepcion SPI",128,NULL,4,NULL);
xTaskCreate(tx_I2C,"Transmision SPI",128,NULL,4,NULL);
/* Finally start the scheduler. */
vTaskStartScheduler();
/* Will only reach here if there is insufficient heap available to start
the scheduler. */
return 0;
now i have another filte to define the tasks:
subfunctions.h
/*********************DEFINICIONES DE TAREAS*********************/
void prep_HARD(void *pvParameters)//Task configs Hardware
//Variables que usa la Funcion
unsigned short usI2CCONValue;
unsigned short usI2CBRGValue;//ACA VA el valor del Baud gen para 100KHz
for(;;)
//Funciones que configuran el hardware
//OSC: ((10MHz/2)*8)/4 = FCY = 10 Mhz
TRISFbits.TRISF6 = 0; //Output RF6/SCK1
TRISFbits.TRISF2 = 1; //Input RF2/SDI1
TRISFbits.TRISF3 = 0; //Output RF3/SDO1
ADPCFGbits.PCFG2 = 1; //Pin RB2 analgoni
TRISBbits.TRISB2 = 0; //Output RB2 (SDC_CS RB2)
LATBbits.LATB2 = 1;
usI2CBRGValue = 0x05A; //100Khz para 10 MHZ de FCY
usI2CCONValue = I2C_ON &
I2C_IDLE_CON &
I2C_CLK_REL &
I2C_IPMI_DIS &
I2C_7BIT_ADD &
I2C_SLW_DIS &
I2C_SM_DIS &
I2C_GCALL_DIS &
I2C_STR_DIS &
I2C_ACK &
I2C_ACK_DIS &
I2C_RCV_DIS &
I2C_STOP_DIS &
I2C_RESTART_DIS &
I2C_START_DIS;
OpenI2C(usI2CCONValue,usI2CBRGValue);
vTaskDelete (NULL);//vTaskDelete se activa en FREERTOSconfig.h
void data_I2C_HANDLE(void *pvParameters)//Task HANDLE I2C DATA I/O
//Variables que usa la Funcion INTERNAMENTE
usAnalisis_data=0x00;
for(;;)
//Funcion que maneja entrada y salida del I2C
xQueueReceive(Queue_I2C_DataHander,&usHan_data,100);
if(usHan_data==0x00)
//vTaskSuspend(NULL);
xQueuePeek(Queue_I2C_DataHander,&usHan_data,100);
if(usHan_data==0xAA)
usTx_data==0x00;
xQueueReceive(Queue_I2C_DataHander,&usAnalisis_data,100);
//mover motores, podria hacer una rutina que mueva motores
//y llamarla con un "for" para la cantidad de pasos
//ahora enviar dato para jeringas ACK 0xFX
usTx_add=(SLAVE_ADD1&W_I2C);
usTx_data=0xFF;//para este caso el analisis es F entonces
//ACK= 0xFX + F = 0xFF
usRx_data=0xBB;
//El codigo siguiente es en caso que la tarea salga del for
//si esto pasa la tarea se borra
vTaskDelete(NULL);
void rx_I2C(void *pvParameters)//Task receiving I2C data
//Variables que usa la Funcion INTERNAMENTE A LA TAREA
for(;;)
//Esta tarea espera el mutex para poder usar la queue
//Funcion que lee el buffer I2C
if(xSemaphoreTake(Mutex_I2C_Ctrl, 50))
usRx_data=0xAA;
xQueueSend(Queue_I2C_DataHander, &usRx_data,100);//Pone el dato en la queue
xSemaphoreGive(Mutex_I2C_Ctrl);
vTaskDelay(200);
//vTaskResume(I2C_HANDLE);
vTaskDelete(NULL);
void tx_I2C(void *pvParameters)//Task sending I2C data
for(;;)
//Funcion que escribe el buffer I2C
usRx_data=0xBB;
vTaskDelay(200);
/*IdleI2C();
StartI2C();
while(I2CCONbits.SEN);//se pone low cuando la secuencia start termina
MasterWriteI2C(usTx_add);//slave address entre parentesis mas bit R/W
IdleI2C();
MasterWriteI2C(usTx_data);
StopI2C();*/
vTaskDelete(NULL);
The higher task runs once and deletes itself this is ok. Now the other 3 task have the same priority
1-the “data_I2C_HANDLE” Task is blockes waiting the queue this is ok.
2-the “rx_I2C” task takes the semaphore and goes one iteration then give the semaphore and blocks.
3-the “rx_I2C” task takes the semaphore after the previous task exceutes and gives the semaphore but it takes the semaphore again and again starving the other two tasks.
after that i get a loop inside the task.c arround this code:
static portTASK_FUNCTION( prvIdleTask, pvParameters )
/* Stop warnings. */
( void ) pvParameters;
for( ;; )
/* See if any tasks have been deleted. */
prvCheckTasksWaitingTermination();
and i keep here forever… could you help me? thanks.
