I tried to download the latest FreeRTOS+TCP lab 150825. However, there is a DOD security protocol that blocks the download. There is no workaround according to security. I need a trusted source for the download. A valid certificate is also required for safety. I may need the download for FreeRTOS+ FAT. Please help
DropBox is a block site. If I did the download at home and emailed it in, it would still be a security violation. I need a certificate that verifies the source. DropBox as a source is the issue. The content at DropBox can be tampered with.
Would it help if I were to provide an MD5 or other checksum for the zip
file, so when you downloaded it you could verify its integrity before
you unzipped the source file?
