sangu-lisa wrote on Thursday, October 11, 2012:
in code directory stricture , in the folder Source\portable\GCC , there are 2 folders
ARM_CM3 and ARM_CM3_MPU . What is the difference between these two ?
Regards
Lisa
Regards
Lisa
rtel wrote on Thursday, October 11, 2012:
One does not use the MPU (memory protection unit) and runs all the tasks in privileged mode. The other does use the MPU and tasks can be created in privileged or unprivileged mode.
http://www.freertos.org/FreeRTOS-MPU-memory-protection-unit.html
So porting “every” arm cortex-m3 microcontroller running on gcc compilor should use portable\GCC\ARM_CM3 folder ? ( if MPU is not needed)
Yes. The code in that directory is the code to use for *all* Cortex-M3 ports that don’t use the MPU, and *all* Cortex-M4 ports that don’t use either the MPU or FPU.
A little confused again… I am sorry for that …
TI has arm cortex M3 based microcontroller
Atmel also has arm cortex M3 based controller
so both of these micro controller running on gcc compiler should use code from portable\GCC\ARM_CM3 folder ?
-Lisa
Yes.
I understood . richardbarry thank you for your immediate response.
i have sent a message to you. hope u see it
Based on the understanding , let me tell you my setup
*** I am porting Microcontroller Samsung XXXX which is based on ARM cortex-m3 on IAR tools **
1) so i dont have to change anything .because Source\portable\IAR\ARM_CM3 code is already present.
2) and Source folder contains queue.c , list.c,tasks.c files and Source\include folder contains other header files necessary
3) and I will create a demo application inside Demo/CORTEX_SamsungXXX_IAR folder
Is this correct way ?
Regards
Lisa
sangu-lisa wrote on Friday, October 12, 2012:
somebody can say YES / NO :))) ??
superb … richard, i would love to see ur replies
-Lisa
sangu-lisa wrote on Monday, October 15, 2012:
i decided to take an already existing demo application and use it.
which DEMO application you suggest for a starter like me ? so that i can do minor modification n reuse it ?
( My set up is mentioned above at reply No 8)
Regards
Lisa
