As title. Does the network lib pass the TC8 test?
Thanks
Xiaoyi
Hi Xiaoyi,
Thanks for the query.
As I understand TC8 is the conformance test for automotive ethernet. We have not tried TC8 yet.
The FreeRTOS+TCP stack is:
- Unit tested
- Validated for CBMC Proofs
- Protocol tested using Maxwell Pro Tester
- Validated using penetration tests
However, we would also like to understand the use case and how important is the TC8 conformity for the end solution. And in case if you are planning to try out the same , we would be more than happy to guide you.
Hi Subhranil,
We would like to try some ADAS L4 prototype using the freertos_tcp if it pass the TC8 conformance test. Or do you know how much work shall be done to make it pass the TC8 test?
Thanks
Xiaoyi
Hi Xiaoyi,
As we have not evaluated TC8 tests, it is not possible to comment on the amount of work required. As Shub already mentioned, if you are planning to try out the same, we would be more than happy to guide you, in case of any issues you face.
