I have project with a STM32L073 Cortex-M0+ and power supply with a battery. To reduce the power consumption I use the configUSE_TICKLESS_IDLE configuration. The configuration of the MCU is generated with CubeMX.
For some timing I use a hardware timer (like TIM6) to generate a 1ms tick.
Now I will disable this timer and for this I will use the SysTick which also used for the HAL and for the FreeRTOS.
Now I have detect that FreeRTOS change the configuration of the SysTick during enter/leave the sleep mode.
I not so heapy about this. The ISR function is called to many times and with a verry short time. And the other 1ms tick functions are not working with the correct cycle time. So I will change this. I will only enable and disable the SysTick when enter/leave the sleep mode and no other functions use this tick.
Exists a solution for deactivation of the SysTick configuration changes from FreeRTOS, so that I can add the disable/enable of the SysTick in the function configPRE_SLEEP_PROCESSING/configPOST_SLEEP_PROCESSING?
Thanks for our help,
Bernd
